Date/Time: Tue, 18 Mar 2025 12:34:44 +0000
Market Depth Bars settings
View Count: 513
[2022-09-21 23:27:01]
DianaPena - Posts: 33
Is it possible for the Market Depth study to show the bars all the way to the left/right, instead of by section?
See attached images for examples and the settings I have.
imageMarket depth 1.png / V - Attached On 2022-09-21 23:26:38 UTC - Size: 28.32 KB - 132 views
imageMarket depth 2.png / V - Attached On 2022-09-21 23:26:45 UTC - Size: 7.7 KB - 129 views
[2022-09-22 14:05:46]
John - SC Support - Posts: 38735
It sounds like the Input you want to use is the Extend Last Known Depth. This will fill in the blank areas with the last known depth value until there is a new value that prints at that level. Refer to the information here:
Market Depth Historical Graph: Extend Last Known Depth
