Date/Time: Sun, 04 Oct 2026 20:52:23 +0000
Alert Sound File Corrupter
View Count: 750
| [2022-09-21 20:34:04] |
| User360283 - Posts: 538 |
Would you Pease emailed me a current Alert Sound file Thank you very much DJ947@yahoo.com |
| [2022-09-21 21:22:03] |
| John - SC Support - Posts: 48095 |
There are a number of alert sounds that are included with Sierra Chart. These files are located under the main Sierra Chart installation folder in a folder named "AlertSounds". For example, if you have installed Sierra Chart to the top of the C: Drive, then the folder that has the Alert sounds would be located at C:\SierraChart\AlertSounds For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-22 12:21:18] |
MY C:\SierraChart\AlertSounds is damaged. After the last upgrade many alerts including "order has be filled", Order has been cancelled" etc. are not working. My PC repair shop added several custom sounds incorrectly. I must get this fixed! I need the standard sound file so I can re-installed it. Help please Thanks please email me the file DJ947@yahoo.com |
| [2022-09-22 15:38:25] |
Here is a zip of the AlertSounds folder.
Private File |
