Date/Time: Sun, 24 Nov 2024 04:40:10 +0000
Hw to set Alert Sound File
View Count: 1004
[2022-09-21 19:40:06] |
User360283 - Posts: 504 |
It seems my alert sound file is disconnected I am suffering from vision deterioration after eye surgery I cannot find where to fix this Please help Thanks a lot |
[2022-09-21 21:13:35] |
In general, the sound files that are used for alerts within Sierra Chart are in a folder named 'AlertSounds' that is located under the main Sierra Chart folder. For example, this would be C:\SierraChart\AlertSounds if you installed Sierra Chart just below the C: drive. If you have the sound file, just place a copy into the 'AlertSounds' folder and then you can use it in your alerts. Refer to the following for information on assigning a particular sound to an alert: General Settings Window: Alert Sound File Name (Global Settings >> General Settings >> Alerts >> Sound File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-22 08:33:10] |
User669552 - Posts: 15 |
How do I create a sound alert that alerts me when ever a new bar is opened or closed. I use a 7 tick range chart.
[2024-06-24 14:15:09] |
We need you to post on the Support Board with an active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
