Date/Time: Tue, 26 Nov 2024 13:46:20 +0000
Timestamp for records in TimeandSales array
View Count: 1224
[2014-05-18 15:42:17] |
User44130 - Posts: 23 |
Hello, I want to get timestamp for records in TimeandSales array. Previously I used the following method to access time data: SCTimeAndSalesArray TimeSales; sc.GetTimeAndSales(TimeSales); TSArrSize = TimeSales.GetArraySize() - 1; SCDateTime TempDateTime = COMBINE_DATE_TIME(10, HMS_TIME(TimeSales[TSIndex].Hour, TimeSales[TSIndex].Minute, TimeSales[TSIndex].Second)) But now I get this error message during compilation: -- Starting build of Custom Studies Source files: AAAProdStudyColl_r6.cpp. -- 09:39:02 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\AAAProdStudyColl_r6.dll" C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp: In function 'void scsf_TickProcLogOut(SCStudyInterfaceRef)': C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp:98:25: error: 'const struct s_TimeAndSales' has no member named 'Second' C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp:118:20: error: 'const struct s_TimeAndSales' has no member named 'Second' C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp:122:119: error: 'const struct s_TimeAndSales' has no member named 'Hour' C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp:122:132: error: 'const struct s_TimeAndSales' has no member named 'Minute' C:\SierraChart\ACS_Source\AAAProdStudyColl_r6.cpp:122:147: error: 'const struct s_TimeAndSales' has no member named 'Second' -- End of Build -- 09:39:03 Please advise the method to get Time and Sales timestaps. Thanks |
[2014-05-18 20:23:39] |
This change was made more than a year ago and is documented on the What is New page. Refer to the SierraChart.h file for the current structure. There is a single SCDateTimeMS DateTime; member containing the date and time. This is the same as SCDateTime, except with millisecond precision. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
