Date/Time: Tue, 18 Mar 2025 10:09:45 +0000
Bar Based Backtest - Force fill price to be the same as order price?
View Count: 348
[2022-09-21 15:28:13] |
jwick - Posts: 142 |
Is there a way to run a bar based backtest and force the fill price of an order (eg: a stop order) to always be the same as the order price? Thanks Date Time Of Last Edit: 2022-09-21 15:43:46
[2022-09-21 22:03:30] |
Sierra_Chart Engineering - Posts: 18817 |
No, this is not supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-21 22:03:35
