Date/Time: Sun, 24 Nov 2024 14:52:09 +0000
1 Cent being Added/Subtracted to P&L
View Count: 794
[2022-09-21 00:02:56] |
connordw - Posts: 44 |
Whenever I take a position that has been entered with two or more orders, there is always $0.01 added to/subtracted from the DOM P&L and also the DPL. For example, in the screen shot 1 attached, I entered a 10 lot buy, and the P&L displays fine. When I add another 10 lots via a second order, as shown in screenshot 2, there is this $0.01 issue. Any ideas on why this is occurring? Also, is it possible to remove the decimal points in the DOM P&L? Thanks for your help. |
[2022-09-21 15:28:02] |
Sierra_Chart Engineering - Posts: 17156 |
Refer to: Trade Activity Log: Profit/Loss Calculation Rounding Error No: Also, is it possible to remove the decimal points in the DOM P&L? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-22 16:31:24] |
grayfrog - Posts: 40 |
Not sure if this is the correct solution but I found that you can get to whole numbers if you do the following Global Settings -> General Trade settings -> Number Decimal Places For Displayed Currency Value -> Set to zero Hope this helps. |
