Date/Time: Wed, 27 Nov 2024 00:33:54 +0000
Help With Converting An Old Cht File
View Count: 957
[2022-09-20 23:05:49]
User483852 - Posts: 16
Could you please let me know how to convert the attached cht file to a current version.
Thank You !
attachmentTPO-Delta-Volume_v1991.Cht - Attached On 2022-09-20 23:05:20 UTC - Size: 205.74 KB - 261 views
[2022-09-21 11:41:44]
Thank you GC5150. It works great. Can you please point me how I can learn to convert to new chartbooks.
[2022-09-21 12:27:29]
Wow. Thats brilliant. Thank You So Much !!!
[2023-10-05 15:47:08]
Khaleddahrouj303 - Posts: 4
Can you please convert those two files to 64bit please because they are not loading i think thats the problem thanks!
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855 (1).Cht - Attached On 2023-10-05 15:45:32 UTC - Size: 276.18 KB - 167 views
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2023-10-05 15:46:09 UTC - Size: 528.28 KB - 140 views
[2023-10-05 19:55:17]
Sierra_Chart Engineering - Posts: 17187
We want you to contact G7FX about these Chartbooks and they will help you.
