Date/Time: Fri, 25 Sep 2026 10:58:01 +0000
Possible?
View Count: 1138
[2022-09-20 16:39:50]
rondawes - Posts: 51
In my short time with SC, I'm continually amazed at what can be done - if you know how. This might fall in to the "not possible" category but I thought I'd ask:
See attached screenshot. The DOM has a combined pulling/stacking column and the summary above/below the active cells. Is it possible to plot or use the summary numbers in a chart or study? Ideally, I'd like to plot the difference of the two, i.e. bid summary - offer summary.
imageScreenshot 2022-09-20 110401.png / V - Attached On 2022-09-20 16:39:05 UTC - Size: 56.05 KB - 265 views
[2022-09-20 17:11:51]
John - SC Support - Posts: 48003
The information is available through the Numbers Bars Calculated Values 2 study, which has subgraphs for the following:
- Sum Bid Pull/Stack
- Sum Ask Pull/Stack
Refer to the information here:
Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions
[2022-09-20 17:44:08]
I was about to post that I found it. I need to do more research before posting questions like that.
