Date/Time: Tue, 18 Mar 2025 12:31:45 +0000
Multiple Daily Loss Values
View Count: 900
[2022-09-20 15:31:42] |
connordw - Posts: 46 |
Is it possible to have multiple daily loss values? For example, I would like lock trading for 10 minutes after an initial daily loss value is met, and then lock trading for the rest of the day day if a second larger daily loss value is met. Thank you.
[2022-09-20 17:03:17] |
John - SC Support - Posts: 38735 |
We do not have this at this time. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 23:57:02] |
Ok thanks. please update if/when this is added.
[2022-09-21 06:59:11] |
Sierra_Chart Engineering - Posts: 18817 |
This is never going to be added. You have to develop this using ACSIL. ACSIL can lock trading and unlock trading. ACSIL can also access historical order fill data. Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-21 06:59:39
