Date/Time: Fri, 11 Sep 2026 20:54:52 +0000
413 Request Entity Too Large
View Count: 1215
| [2022-09-20 15:01:16] |
| User462086 - Posts: 202 |
Just got this message after adding a few studies to a common .cpp file filled with studies and supporting functions. Used the Remote Build. The file size is 1,121 kb. The remote build did not succeed. Result: <html> <head><title>413 Request Entity Too Large</title></head> <body bgcolor="white"> <center><h1>413 Request Entity Too Large</h1></center> <hr><center>nginx/1.13.12</center> </body> </html> What are my options for keeping similar studies together in the same .dll if they can't be kept in the same .cpp file due to this size limitation? |
| [2022-09-20 15:15:25] |
| Sierra_Chart Engineering - Posts: 24839 |
We will check on this.
| [2022-09-21 02:23:30] |
Please try again now, and let us know if you are still seeing the issue.
Sierra Chart Support |
| [2022-09-21 03:03:32] |
"The remote build succeeded." Thank you!! |
