Date/Time: Fri, 18 Sep 2026 06:27:19 +0000
Connected to Data Feed - Chart Loaded No Price Movement in Chart
View Count: 1218
| [2022-09-20 14:36:04] |
| User149333 - Posts: 23 |
Hi, I started Sierra for the first time in a few days & the behaviour described in in the title is evident. Thinking an update was required, I ran it & the problem is still there. I have looked at feeds, everything is in credit. I have tried doing a symbol rollover but I just had the chart with zero activity and had 'waiting to download historical data' for much longer than usual. This has now disappeared. Data window is green, so I must be connected. I'm using Teton & tried switching to 'all services' but nothings changed still have a chart with price stalled at Friday 9:25:56. Please can you help? Reading Internal Order ID file. | 2022-09-20 10:02:52.120 Reading Trade Orders file. | 2022-09-20 10:02:52.247 Reading Trade Positions file. | 2022-09-20 10:02:52.249 Reading Trade Account Data files. | 2022-09-20 10:02:52.250 UDPListener (636). Port 22904 | Listening on UDP port 22904. | 2022-09-20 10:02:52.525 Software version: 2439 64-bit | 2022-09-20 10:02:52.525 Primary Thread ID: 444 | 2022-09-20 10:02:52.525 Usage end date: 2022-10-11 | 2022-09-20 10:02:52.526 Enabled for: Sierra Chart Historical Data Service. | 2022-09-20 10:02:52.526 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-09-20 10:02:52.526 Enabled for: Delayed Denali Exchange Data Feed. | 2022-09-20 10:02:52.526 Enabled for exchange2: CME (Trading Account Required) | 2022-09-20 10:02:52.526 Enabled for exchange2: CBOT (Trading Account Required) | 2022-09-20 10:02:52.526 Enabled for exchange2: COMEX (Trading Account Required) | 2022-09-20 10:02:52.526 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-09-20 10:02:52.526 Enabled for exchange2: fairx_exchange.data | 2022-09-20 10:02:52.526 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-09-20 10:02:52.526 Current selected Data/Trading service: Teton CME Order Routing | 2022-09-20 10:02:52.526 Custom symbol settings values: disabled | 2022-09-20 10:02:52.526 Chart Update Interval: 10 | 2022-09-20 10:02:52.526 Intraday Data Storage Time Unit: 0 | 2022-09-20 10:02:52.526 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-09-20 10:02:52.526 2022-09-20 14:02:52 Local computer time in UTC | 2022-09-20 10:02:52.526 2022-09-20 10:02:52 Local computer time in SC Time Zone | 2022-09-20 10:02:52.526 2022-09-20 14:02:50 Server time in UTC | 2022-09-20 10:02:52.526 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-09-20 10:02:52.526 Program path: C:\Program Files (x86)\SierraChart\ | 2022-09-20 10:02:52.526 Data Files path: C:\Program Files (x86)\SierraChart\Data\ | 2022-09-20 10:02:52.526 OS Version Number: 6.1 | 2022-09-20 10:02:52.526 Locale Setting: C | 2022-09-20 10:02:52.526 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-09-20 10:02:52.528 Allowed protected custom studies: | 2022-09-20 10:02:52.528 Crash reporter started: true | 2022-09-20 10:02:52.528 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2022-09-20 10:02:52.548 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:02:52.650 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-09-20 10:02:52.732 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-09-20 10:02:52.732 Received 5 login tokens. | 2022-09-20 10:02:52.802 Symbol settings MD5 received. Request ID: 1. | 2022-09-20 10:02:54.303 Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. | 2022-09-20 10:02:54.305 Symbol settings received. Request ID: 2. | 2022-09-20 10:02:56.189 Teton CME Order Routing | Firm: Dorman | 2022-09-20 10:02:58.954 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-09-20 10:02:58.955 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-09-20 10:02:58.957 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-20 10:02:58.957 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-09-20 10:02:58.957 Teton CME Order Routing | Network connection to server complete. | 2022-09-20 10:02:59.104 Teton CME Order Routing | Starting socket receive thread. | 2022-09-20 10:02:59.104 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-09-20 10:02:59.105 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-09-20 10:02:59.541 Teton CME Order Routing | Sending logon request message. | 2022-09-20 10:02:59.541 Teton CME Order Routing | Received logon response. | 2022-09-20 10:03:00.242 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-09-20 10:03:00.243 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:03:00.243 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-09-20 10:03:00.243 Teton CME Order Routing | Trading is supported. | 2022-09-20 10:03:00.243 Teton CME Order Routing | Order cancel and replace is supported. | 2022-09-20 10:03:00.243 Teton CME Order Routing | OCO Orders supported. | 2022-09-20 10:03:00.243 Teton CME Order Routing | Bracket Orders supported. | 2022-09-20 10:03:00.243 Teton CME Order Routing | Connected to server complete. | 2022-09-20 10:03:00.243 Triggering next historical data download in queue. | 2022-09-20 10:03:00.244 Triggering next historical data download in queue. | 2022-09-20 10:03:00.244 Triggering next historical data download in queue. | 2022-09-20 10:03:00.244 Triggering next historical data download in queue. | 2022-09-20 10:03:00.244 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:03:00.245 Mapping NQM18_FUT_CME to NQM18. Service code: cme | 2022-09-20 10:03:00.249 Using symbol data fast lookup vector | 2022-09-20 10:03:00.250 SC Data - All Services | Starting real-time market data updates for: NQM18_FUT_CME (NQM18). ID: 1 Service code: cme | 2022-09-20 10:03:00.251 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 443 | 2022-09-20 10:03:00.251 DTC Client socket (2) | Creating socket. | 2022-09-20 10:03:00.252 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-09-20 10:03:00.252 DTC Client socket (2) | Connecting to IP: 142.215.18.107. | 2022-09-20 10:03:00.253 SC Data - All Services | Requesting security definition data for: NQM18_FUT_CME (NQM18). ID: 1 | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Mapping NQM19_FUT_CME to NQM19. Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Starting real-time market data updates for: NQM19_FUT_CME (NQM19). ID: 2 Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Requesting security definition data for: NQM19_FUT_CME (NQM19). ID: 2 | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Mapping NQU19_FUT_CME to NQU19. Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Starting real-time market data updates for: NQU19_FUT_CME (NQU19). ID: 3 Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Requesting security definition data for: NQU19_FUT_CME (NQU19). ID: 3 | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.260 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.260 Mapping MNQU19_FUT_CME to MNQU19. Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Starting real-time market data updates for: MNQU19_FUT_CME (MNQU19). ID: 4 Service code: cme | 2022-09-20 10:03:00.260 SC Data - All Services | Requesting security definition data for: MNQU19_FUT_CME (MNQU19). ID: 4 | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:03:00.261 Mapping MNQZ19_FUT_CME to MNQZ19. Service code: cme | 2022-09-20 10:03:00.261 SC Data - All Services | Starting real-time market data updates for: MNQZ19_FUT_CME (MNQZ19). ID: 5 Service code: cme | 2022-09-20 10:03:00.261 SC Data - All Services | Requesting security definition data for: MNQZ19_FUT_CME (MNQZ19). ID: 5 | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:03:00.261 Mapping MNQH20_FUT_CME to MNQH20. Service code: cme | 2022-09-20 10:03:00.261 SC Data - All Services | Starting real-time market data updates for: MNQH20_FUT_CME (MNQH20). ID: 6 Service code: cme | 2022-09-20 10:03:00.261 SC Data - All Services | Requesting security definition data for: MNQH20_FUT_CME (MNQH20). ID: 6 | 2022-09-20 10:03:00.261 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:03:00.261 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-09-20 10:03:00.272 No download requests in the queue to start downloads for. | 2022-09-20 10:03:00.272 No download requests in the queue to start downloads for. | 2022-09-20 10:03:00.273 No download requests in the queue to start downloads for. | 2022-09-20 10:03:00.273 No download requests in the queue to start downloads for. | 2022-09-20 10:03:00.273 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-09-20 13:41:04.765388 | 2022-09-20 10:03:00.275 SC Data - All Services | Network connection to server complete. | 2022-09-20 10:03:00.373 SC Data - All Services | Starting socket receive thread. | 2022-09-20 10:03:00.373 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-20 10:03:00.373 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM18_FUT_CME | 2022-09-20 10:03:00.403 Teton CME Order Routing | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:03:00.403 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM19_FUT_CME | 2022-09-20 10:03:00.403 Teton CME Order Routing | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:03:00.403 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQU19_FUT_CME | 2022-09-20 10:03:00.403 Teton CME Order Routing | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:03:00.403 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU19_FUT_CME | 2022-09-20 10:03:00.463 Teton CME Order Routing | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:03:00.463 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ19_FUT_CME | 2022-09-20 10:03:00.463 Teton CME Order Routing | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:03:00.463 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH20_FUT_CME | 2022-09-20 10:03:00.463 Teton CME Order Routing | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:03:00.463 Updated verified funded futures trading account ending date to: 2022-10-20 14:03:00 | 2022-09-20 10:03:00.464 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43699 | 2022-09-20 10:03:00.465 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-20 10:03:07.207 SC Data - All Services | Sending logon request message. | 2022-09-20 10:03:07.207 SC Data - All Services | Received logon response. | 2022-09-20 10:03:08.081 SC Data - All Services | Server Name: SC Realtime Server. | 2022-09-20 10:03:08.082 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:03:08.082 SC Data - All Services | Successfully connected. | 2022-09-20 10:03:08.082 SC Data - All Services | Trading is not supported. | 2022-09-20 10:03:08.082 SC Data - All Services | Restarting real-time data updates for symbol: MNQH20_FUT_CME -> MNQH20 | 2022-09-20 10:03:08.083 SC Data - All Services | Restarting real-time data updates for symbol: MNQU19_FUT_CME -> MNQU19 | 2022-09-20 10:03:08.083 SC Data - All Services | Restarting real-time data updates for symbol: MNQZ19_FUT_CME -> MNQZ19 | 2022-09-20 10:03:08.083 SC Data - All Services | Restarting real-time data updates for symbol: NQM18_FUT_CME -> NQM18 | 2022-09-20 10:03:08.083 SC Data - All Services | Restarting real-time data updates for symbol: NQM19_FUT_CME -> NQM19 | 2022-09-20 10:03:08.083 SC Data - All Services | Restarting real-time data updates for symbol: NQU19_FUT_CME -> NQU19 | 2022-09-20 10:03:08.083 SC Data - All Services | Real-time data for symbol MNQH20_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:03:08.343 SC Data - All Services | Real-time data for symbol MNQU19_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:03:08.343 SC Data - All Services | Real-time data for symbol MNQZ19_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:03:08.343 SC Data - All Services | Real-time data for symbol NQM18_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:03:08.343 SC Data - All Services | Real-time data for symbol NQM19_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:03:08.343 SC Data - All Services | Real-time data for symbol NQU19_FUT_CME is currently unavailable. | 2022-09-20 10:03:08.343 SC Data - All Services | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:03:08.343 MYMU22_FUT_CME [CV] 20 Sec #1 | Reloading chart. | 2022-09-20 10:03:24.239 MYMU22_FUT_CME [CV] 20 Sec #1 | Performing continuous chart historical Daily data download for symbol MYMU22_FUT_CME starting at last date in file. | 2022-09-20 10:03:24.245 Starting DelayedDownloadMonitoringTimer | 2022-09-20 10:03:24.245 Starting HDTimeoutTimer | 2022-09-20 10:03:24.245 Added historical Daily data request for MYMU22_FUT_CME to the queue. | 2022-09-20 10:03:24.246 Triggering next historical data download in queue. | 2022-09-20 10:03:24.246 MYMU22_FUT_CME [CV] 20 Sec #1 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.257 MYMU22_FUT_CME [CV] 20 Sec #3 | Reloading chart. | 2022-09-20 10:03:24.275 MYMU22_FUT_CME [CV] 20 Sec #3 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.287 UserContributedStudies.dll is not 64-bit | 2022-09-20 10:03:24.292 VersionNumber is 0 for UserContributedStudies.dll | 2022-09-20 10:03:24.292 Loading DLL: C:\Program Files (x86)\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 16c60000 | 2022-09-20 10:03:24.303 MYMU22_FUT_CME [CV] 20 Sec #2 | Reloading chart. | 2022-09-20 10:03:24.355 MYMU22_FUT_CME [CV] 20 Sec #2 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.371 MYMU22_FUT_CME [CV] 20 Sec #4 | Reloading chart. | 2022-09-20 10:03:24.413 MYMU22_FUT_CME [CV] 20 Sec #4 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.425 MYMU22_FUT_CME [CV] 20 Sec #5 | Reloading chart. | 2022-09-20 10:03:24.550 MYMU22_FUT_CME [CV] 20 Sec #5 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.566 MYMU22_FUT_CME [CV] Renko 10t #6 | Reloading chart. | 2022-09-20 10:03:24.622 MYMU22_FUT_CME [CV] Renko 10t #6 | Waiting for historical downloads to complete with the IDs: 1, | 2022-09-20 10:03:24.635 MNQU22_FUT_CME [CV] Renko 20t #7 | Reloading chart. | 2022-09-20 10:03:24.692 Starting DelayedDownloadMonitoringTimer | 2022-09-20 10:03:24.697 Starting HDTimeoutTimer | 2022-09-20 10:03:24.697 Added historical Intraday data request for MNQM22_FUT_CME to the queue. | 2022-09-20 10:03:24.697 Triggering next historical data download in queue. | 2022-09-20 10:03:24.698 MNQU22_FUT_CME [CV] Renko 20t #7 | Performing continuous chart historical Daily data download for symbol MNQU22_FUT_CME starting at last date in file. | 2022-09-20 10:03:24.700 Added historical Daily data request for MNQU22_FUT_CME to the queue. | 2022-09-20 10:03:24.700 MNQU22_FUT_CME [CV] Renko 20t #7 | Waiting for historical downloads to complete with the IDs: 2, 3, | 2022-09-20 10:03:24.711 Mapping MYMU22_FUT_CME to MYMU22. Service code: cbot | 2022-09-20 10:03:24.760 HD Request # 1 | Downloading Historical Daily chart data for MYMU22_FUT_CME. Starting date: 2022-09-14. Service: sc_futures_direct.dtc.trading | 2022-09-20 10:03:24.761 Mapping MNQM22_FUT_CME to MNQM22. Service code: cme | 2022-09-20 10:03:24.763 HD Request # 2 | Downloading Intraday chart data for MNQM22_FUT_CME to the file MNQM22_FUT_CME.scid. Service: cme | 2022-09-20 10:03:24.764 HD Request # 2 | Download start date-time: 2022-05-12 13:57:18.000000. File last date-time: 2022-05-12 13:57:18.436000 | 2022-09-20 10:03:24.765 HD Request # 2 | Using server: ds23.sierracharts.com port 10150 | 2022-09-20 10:03:24.765 Socket (4) | Creating socket. | 2022-09-20 10:03:24.766 Socket (4) | New receive buffer size: 5242880 | 2022-09-20 10:03:24.766 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:03:24.766 HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-09-20 10:03:25.083 HD Request # 2 | Sending historical data logon request message. | 2022-09-20 10:03:25.083 HD Request # 1 | Requesting historical Daily data for YRU22 starting at 2022-09-13. SC External HD service. | 2022-09-20 10:03:25.146 HD Request # 1 | Receiving historical Daily data for MYMU22_FUT_CME starting at 2022-09-14. | 2022-09-20 10:03:25.624 HD Request # 1 | Writing historical Daily data to the file MYMU22_FUT_CME.dly. | 2022-09-20 10:03:25.625 HD Request # 1 | Bytes received: 207 | 2022-09-20 10:03:25.628 HD Request # 1 | Received 4 Daily data records from 2022-09-14 00:00:00 to 2022-09-16 00:00:00 (3.0 days) and wrote 3 records for MYMU22_FUT_CME | 2022-09-20 10:03:25.628 HD Request # 1 | Completion time: 1s. | 2022-09-20 10:03:25.629 HD Request # 1 | Daily data download complete for MYMU22_FUT_CME. Unique request ID: 1 | 2022-09-20 10:03:25.629 Removing historical data download ID 1. | 2022-09-20 10:03:25.629 Triggering next historical data download in queue. | 2022-09-20 10:03:25.630 Mapping MNQU22_FUT_CME to MNQU22. Service code: cme | 2022-09-20 10:03:25.630 HD Request # 3 | Downloading Historical Daily chart data for MNQU22_FUT_CME. Starting date: 2022-09-14. Service: sc_futures_direct.dtc.trading | 2022-09-20 10:03:25.632 MYMU22_FUT_CME [CV] 20 Sec #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.635 MYMU22_FUT_CME [CV] 20 Sec #4 | Reloading chart. | 2022-09-20 10:03:25.636 MYMU22_FUT_CME [CV] 20 Sec #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.654 MYMU22_FUT_CME [CV] 20 Sec #2 | Reloading chart. | 2022-09-20 10:03:25.657 MYMU22_FUT_CME [CV] 20 Sec #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.671 MYMU22_FUT_CME [CV] 20 Sec #3 | Reloading chart. | 2022-09-20 10:03:25.672 MYMU22_FUT_CME [CV] 20 Sec #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.684 MYMU22_FUT_CME [CV] 20 Sec #1 | Reloading chart. | 2022-09-20 10:03:25.685 MYMU22_FUT_CME [CV] 20 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.700 MYMU22_FUT_CME [CV] 20 Sec #5 | Reloading chart. | 2022-09-20 10:03:25.703 HD Request # 2 | Requesting Intraday data. Start date-time: 2022-05-12 13:57:18. Record interval: 0. Symbol: MNQM22 | 2022-09-20 10:03:25.722 MYMU22_FUT_CME [CV] Renko 10t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:03:25.728 MYMU22_FUT_CME [CV] Renko 10t #6 | Reloading chart. | 2022-09-20 10:03:25.731 MYMU22_FUT_CME [CV] 20 Sec #4 | Reloading chart. | 2022-09-20 10:03:25.749 MYMU22_FUT_CME [CV] 20 Sec #2 | Reloading chart. | 2022-09-20 10:03:25.784 MYMU22_FUT_CME [CV] 20 Sec #3 | Reloading chart. | 2022-09-20 10:03:25.828 MYMU22_FUT_CME [CV] 20 Sec #1 | Reloading chart. | 2022-09-20 10:03:25.864 HD Request # 2 | Decompressing data. | 2022-09-20 10:03:25.879 HD Request # 2 | Receiving Intraday data for MNQM22_FUT_CME starting at 2022-05-12 13:57:18.019000 | 2022-09-20 10:03:25.896 MYMU22_FUT_CME [CV] 20 Sec #5 | Reloading chart. | 2022-09-20 10:03:25.905 MYMU22_FUT_CME [CV] Renko 10t #6 | Reloading chart. | 2022-09-20 10:03:25.946 SC Data - All Services | Starting real-time market data updates for: MYMU22_FUT_CME (MYMU22). ID: 7 Service code: cbot | 2022-09-20 10:03:25.984 SC Data - All Services | Requesting security definition data for: MYMU22_FUT_CME (MYMU22). ID: 7 | 2022-09-20 10:03:25.985 Added historical Intraday data request for MYMU22_FUT_CME to the queue. | 2022-09-20 10:03:25.986 Intraday data recording state for symbol MYMU22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:03:25.986 Triggering next historical data download in queue. | 2022-09-20 10:03:25.986 HD Request # 3 | Requesting historical Daily data for NMU22 starting at 2022-09-13. SC External HD service. | 2022-09-20 10:03:26.095 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMU22_FUT_CME | 2022-09-20 10:03:26.128 Teton CME Order Routing | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:03:26.128 SC Data - All Services | Real-time data for symbol MYMU22_FUT_CME is currently unavailable. | 2022-09-20 10:03:26.206 SC Data - All Services | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:03:26.206 HD Request # 3 | Receiving historical Daily data for MNQU22_FUT_CME starting at 2022-09-14. | 2022-09-20 10:03:26.377 HD Request # 3 | Writing historical Daily data to the file MNQU22_FUT_CME.dly. | 2022-09-20 10:03:26.377 HD Request # 3 | Bytes received: 230 | 2022-09-20 10:03:26.380 HD Request # 3 | Received 4 Daily data records from 2022-09-14 00:00:00 to 2022-09-16 00:00:00 (3.0 days) and wrote 3 records for MNQU22_FUT_CME | 2022-09-20 10:03:26.380 HD Request # 3 | Completion time: 1s. | 2022-09-20 10:03:26.380 HD Request # 3 | Daily data download complete for MNQU22_FUT_CME. Unique request ID: 3 | 2022-09-20 10:03:26.380 Removing historical data download ID 3. | 2022-09-20 10:03:26.380 Triggering next historical data download in queue. | 2022-09-20 10:03:26.380 No download requests in the queue to start downloads for. | 2022-09-20 10:03:26.380 HD Request # 2 | Timestamp of first Intraday data file record written: 2022-05-12 13:57:18.436001. | 2022-09-20 10:03:27.552 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:30.650 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:31.491 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:33.737 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:34.330 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:34.980 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:03:37.096 MYMU22_FUT_CME [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:03:56.771 MYMU22_FUT_CME [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:03:56.806 MYMU22_FUT_CME [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:03:56.836 MYMU22_FUT_CME [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:03:56.874 MYMU22_FUT_CME [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:03:56.914 MYMU22_FUT_CME [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:03:56.958 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:01.665 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:02.237 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:04.124 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:04.739 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:05.462 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:04:07.677 Saved Chartbook: Volume Divergence.Cht. Time: 0.0399 seconds. | 2022-09-20 10:06:30.253 MYMU22_FUT_CME [CV] 20 Sec #1 | Reloading chart. | 2022-09-20 10:06:34.418 MYMU22_FUT_CME [CV] 20 Sec #3 | Reloading chart. | 2022-09-20 10:06:34.548 MYMU22_FUT_CME [CV] 20 Sec #2 | Reloading chart. | 2022-09-20 10:06:34.631 MYMU22_FUT_CME [CV] 20 Sec #4 | Reloading chart. | 2022-09-20 10:06:34.717 MYMU22_FUT_CME [CV] 20 Sec #5 | Reloading chart. | 2022-09-20 10:06:34.937 MYMU22_FUT_CME [CV] Renko 10t #6 | Reloading chart. | 2022-09-20 10:06:35.061 MNQU22_FUT_CME [CV] Renko 20t #7 | Reloading chart. | 2022-09-20 10:06:35.187 MNQU22_FUT_CME [CV] Renko 20t #7 | Waiting for historical downloads to complete with the IDs: 2, | 2022-09-20 10:06:35.219 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:39.382 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:40.495 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:41.263 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:41.840 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:42.619 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:45.707 MYMM22_FUT_CME [CV] Renko 10t #1 | Reloading chart. | 2022-09-20 10:06:55.559 MYMM22_FUT_CME [CV] Renko 10t #1 | Performing continuous chart historical Daily data download for symbol MYMM22_FUT_CME starting at last date in file. | 2022-09-20 10:06:55.561 Added historical Daily data request for MYMM22_FUT_CME to the queue. | 2022-09-20 10:06:55.561 Triggering next historical data download in queue. | 2022-09-20 10:06:55.561 MYMM22_FUT_CME [CV] Renko 10t #1 | Waiting for historical downloads to complete with the IDs: 5, | 2022-09-20 10:06:55.566 MYMM22_FUT_CME [CV] Renko 10t #2 | Reloading chart. | 2022-09-20 10:06:55.622 MYMM22_FUT_CME [CV] Renko 10t #2 | Waiting for historical downloads to complete with the IDs: 5, | 2022-09-20 10:06:55.629 MYMU22_FUT_CME [CV] 60 Min #4 | Reloading chart. | 2022-09-20 10:06:55.689 MYMU22_FUT_CME [CV] 60 Min #4 | Waiting for historical downloads to complete with the IDs: 5, | 2022-09-20 10:06:55.704 MYMU22_FUT_CME [CV] Renko 8t #3 | Reloading chart. | 2022-09-20 10:06:55.883 MYMU22_FUT_CME [CV] Renko 8t #3 | Waiting for historical downloads to complete with the IDs: 5, | 2022-09-20 10:06:55.896 Mapping MYMM22_FUT_CME to MYMM22. Service code: cbot | 2022-09-20 10:06:55.954 HD Request # 4 | Downloading Historical Daily chart data for MYMM22_FUT_CME. Starting date: 2022-06-15. Service: sc_futures_direct.dtc.trading | 2022-09-20 10:06:55.955 HD Request # 4 | Requesting historical Daily data for YRM22 starting at 2022-06-14. SC External HD service. | 2022-09-20 10:06:56.376 HD Request # 4 | Receiving historical Daily data for MYMM22_FUT_CME starting at 2022-06-15. | 2022-09-20 10:06:56.683 HD Request # 4 | Writing historical Daily data to the file MYMM22_FUT_CME.dly. | 2022-09-20 10:06:56.683 HD Request # 4 | Bytes received: 207 | 2022-09-20 10:06:56.684 HD Request # 4 | Received 4 Daily data records from 2022-06-15 00:00:00 to 2022-06-17 00:00:00 (3.0 days) and wrote 3 records for MYMM22_FUT_CME | 2022-09-20 10:06:56.684 HD Request # 4 | Completion time: 1s. | 2022-09-20 10:06:56.684 HD Request # 4 | Daily data download complete for MYMM22_FUT_CME. Unique request ID: 5 | 2022-09-20 10:06:56.684 Removing historical data download ID 5. | 2022-09-20 10:06:56.684 Triggering next historical data download in queue. | 2022-09-20 10:06:56.684 No download requests in the queue to start downloads for. | 2022-09-20 10:06:56.684 MYMU22_FUT_CME [CV] 60 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:06:56.685 MYMU22_FUT_CME [CV] 60 Min #4 | Reloading chart. | 2022-09-20 10:06:56.686 MYMM22_FUT_CME [CV] Renko 10t #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:06:56.702 MYMM22_FUT_CME [CV] Renko 10t #1 | Reloading chart. | 2022-09-20 10:06:56.702 MYMU22_FUT_CME [CV] Renko 8t #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:06:56.713 MYMU22_FUT_CME [CV] Renko 8t #3 | Reloading chart. | 2022-09-20 10:06:56.714 MYMM22_FUT_CME [CV] Renko 10t #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:06:56.729 MYMM22_FUT_CME [CV] Renko 10t #2 | Reloading chart. | 2022-09-20 10:06:56.730 MYMU22_FUT_CME [CV] 60 Min #4 | Reloading chart. | 2022-09-20 10:06:56.741 MYMM22_FUT_CME [CV] Renko 10t #1 | Reloading chart. | 2022-09-20 10:06:56.777 MYMU22_FUT_CME [CV] Renko 8t #3 | Reloading chart. | 2022-09-20 10:06:56.795 MYMM22_FUT_CME [CV] Renko 10t #2 | Reloading chart. | 2022-09-20 10:06:56.838 SC Data - All Services | Starting real-time market data updates for: MYMM22_FUT_CME (MYMM22). ID: 10 Service code: cbot | 2022-09-20 10:06:56.861 SC Data - All Services | Requesting security definition data for: MYMM22_FUT_CME (MYMM22). ID: 10 | 2022-09-20 10:06:56.862 Added historical Intraday data request for MYMM22_FUT_CME to the queue. | 2022-09-20 10:06:56.862 Intraday data recording state for symbol MYMM22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:06:56.862 Triggering next historical data download in queue. | 2022-09-20 10:06:56.862 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMM22_FUT_CME | 2022-09-20 10:06:57.005 Teton CME Order Routing | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:06:57.005 SC Data - All Services | Real-time data for symbol MYMM22_FUT_CME is currently unavailable. | 2022-09-20 10:06:57.069 SC Data - All Services | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:06:57.069 MYMM22_FUT_CME [CV][M] Renko 10t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:58.181 MYMM22_FUT_CME [CV][M] Renko 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:06:58.321 MYMU22_FUT_CME [CV][M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:07:00.275 MYMU22_FUT_CME [CV][M] Renko 8t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:07:02.948 File >> Disconnect selected. | 2022-09-20 10:08:04.895 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-09-20 10:08:04.941 DTC Client socket (1) | CloseSocket call. | 2022-09-20 10:08:04.945 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:08:04.945 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-20 10:08:04.946 DTC Client socket (2) | CloseSocket call. | 2022-09-20 10:08:04.946 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:08:04.946 SC Data - All Services | Disconnected from the server. | 2022-09-20 10:08:04.946 Teton CME Order Routing | Disconnected. | 2022-09-20 10:08:04.947 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-20 10:08:05.086 DTC Client socket (1) | Closed. | 2022-09-20 10:08:05.086 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-09-20 10:08:05.376 DTC Client socket (2) | Closed. | 2022-09-20 10:08:05.376 Teton CME Order Routing | Firm: Dorman | 2022-09-20 10:08:10.323 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-09-20 10:08:10.323 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-09-20 10:08:10.327 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-20 10:08:10.327 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-09-20 10:08:10.327 Teton CME Order Routing | Network connection to server complete. | 2022-09-20 10:08:10.475 Teton CME Order Routing | Starting socket receive thread. | 2022-09-20 10:08:10.475 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-09-20 10:08:10.475 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-09-20 10:08:10.912 Teton CME Order Routing | Sending logon request message. | 2022-09-20 10:08:10.912 Teton CME Order Routing | Received logon response. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:08:11.572 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Trading is supported. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Order cancel and replace is supported. | 2022-09-20 10:08:11.572 Teton CME Order Routing | OCO Orders supported. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Bracket Orders supported. | 2022-09-20 10:08:11.572 Teton CME Order Routing | Connected to server complete. | 2022-09-20 10:08:11.572 Triggering next historical data download in queue. | 2022-09-20 10:08:11.574 Triggering next historical data download in queue. | 2022-09-20 10:08:11.574 Triggering next historical data download in queue. | 2022-09-20 10:08:11.574 Triggering next historical data download in queue. | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:08:11.574 Mapping NQM18_FUT_CME to NQM18. Service code: cme | 2022-09-20 10:08:11.574 Using symbol data fast lookup vector | 2022-09-20 10:08:11.574 SC Data - All Services | Starting real-time market data updates for: NQM18_FUT_CME (NQM18). ID: 1 Service code: cme | 2022-09-20 10:08:11.574 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-09-20 10:08:11.574 SC Data - All Services | Requesting security definition data for: NQM18_FUT_CME (NQM18). ID: 1 | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:08:11.574 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.574 Mapping NQM19_FUT_CME to NQM19. Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Starting real-time market data updates for: NQM19_FUT_CME (NQM19). ID: 2 Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Requesting security definition data for: NQM19_FUT_CME (NQM19). ID: 2 | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Mapping NQU19_FUT_CME to NQU19. Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Starting real-time market data updates for: NQU19_FUT_CME (NQU19). ID: 3 Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Requesting security definition data for: NQU19_FUT_CME (NQU19). ID: 3 | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Mapping MNQU19_FUT_CME to MNQU19. Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Starting real-time market data updates for: MNQU19_FUT_CME (MNQU19). ID: 4 Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Requesting security definition data for: MNQU19_FUT_CME (MNQU19). ID: 4 | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:08:11.575 DTC Client socket (2) | Creating socket. | 2022-09-20 10:08:11.575 Mapping MNQZ19_FUT_CME to MNQZ19. Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Starting real-time market data updates for: MNQZ19_FUT_CME (MNQZ19). ID: 5 Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Requesting security definition data for: MNQZ19_FUT_CME (MNQZ19). ID: 5 | 2022-09-20 10:08:11.575 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:08:11.575 Mapping MNQH20_FUT_CME to MNQH20. Service code: cme | 2022-09-20 10:08:11.575 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:08:11.575 SC Data - All Services | Starting real-time market data updates for: MNQH20_FUT_CME (MNQH20). ID: 6 Service code: cme | 2022-09-20 10:08:11.575 SC Data - All Services | Requesting security definition data for: MNQH20_FUT_CME (MNQH20). ID: 6 | 2022-09-20 10:08:11.575 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:08:11.575 Updated verified funded futures trading account ending date to: 2022-10-20 14:08:11 | 2022-09-20 10:08:11.575 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-09-20 10:08:11.580 No download requests in the queue to start downloads for. | 2022-09-20 10:08:11.580 No download requests in the queue to start downloads for. | 2022-09-20 10:08:11.580 No download requests in the queue to start downloads for. | 2022-09-20 10:08:11.580 Mapping MYMU22_FUT_CME to MYMU22. Service code: cbot | 2022-09-20 10:08:11.581 SC Data - All Services | Starting real-time market data updates for: MYMU22_FUT_CME (MYMU22). ID: 7 Service code: cbot | 2022-09-20 10:08:11.581 SC Data - All Services | Requesting security definition data for: MYMU22_FUT_CME (MYMU22). ID: 7 | 2022-09-20 10:08:11.581 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-09-20 13:41:04.765388 | 2022-09-20 10:08:11.581 Mapping MYMM22_FUT_CME to MYMM22. Service code: cbot | 2022-09-20 10:08:11.610 SC Data - All Services | Starting real-time market data updates for: MYMM22_FUT_CME (MYMM22). ID: 8 Service code: cbot | 2022-09-20 10:08:11.610 SC Data - All Services | Requesting security definition data for: MYMM22_FUT_CME (MYMM22). ID: 8 | 2022-09-20 10:08:11.610 SC Data - All Services | Network connection to server complete. | 2022-09-20 10:08:11.698 SC Data - All Services | Starting socket receive thread. | 2022-09-20 10:08:11.698 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-20 10:08:11.698 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM18_FUT_CME | 2022-09-20 10:08:11.722 Teton CME Order Routing | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:08:11.722 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM19_FUT_CME | 2022-09-20 10:08:11.722 Teton CME Order Routing | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:08:11.722 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQU19_FUT_CME | 2022-09-20 10:08:11.722 Teton CME Order Routing | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:08:11.722 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU19_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:08:11.796 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ19_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:08:11.796 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH20_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:08:11.796 Updated verified funded futures trading account ending date to: 2022-10-20 14:08:11 | 2022-09-20 10:08:11.796 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMU22_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43699 | 2022-09-20 10:08:11.796 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMM22_FUT_CME | 2022-09-20 10:08:11.796 Teton CME Order Routing | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:08:11.796 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-20 10:08:11.847 SC Data - All Services | Sending logon request message. | 2022-09-20 10:08:11.847 SC Data - All Services | Received logon response. | 2022-09-20 10:08:12.676 SC Data - All Services | Server Name: SC Realtime Server. | 2022-09-20 10:08:12.676 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:08:12.676 SC Data - All Services | Successfully connected. | 2022-09-20 10:08:12.676 SC Data - All Services | Trading is not supported. | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: MNQH20_FUT_CME -> MNQH20 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: MNQU19_FUT_CME -> MNQU19 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: MNQZ19_FUT_CME -> MNQZ19 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: MYMM22_FUT_CME -> MYMM22 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: MYMU22_FUT_CME -> MYMU22 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: NQM18_FUT_CME -> NQM18 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: NQM19_FUT_CME -> NQM19 | 2022-09-20 10:08:12.676 SC Data - All Services | Restarting real-time data updates for symbol: NQU19_FUT_CME -> NQU19 | 2022-09-20 10:08:12.676 SC Data - All Services | Real-time data for symbol MNQH20_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol MNQU19_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol MNQZ19_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol MYMM22_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol MYMU22_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol NQM18_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol NQM19_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:08:12.916 SC Data - All Services | Real-time data for symbol NQU19_FUT_CME is currently unavailable. | 2022-09-20 10:08:12.916 SC Data - All Services | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:08:12.916 MYMU22_FUT_CME [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:08:31.367 MYMU22_FUT_CME [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:08:31.397 MYMU22_FUT_CME [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:08:31.427 MYMU22_FUT_CME [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:08:31.462 MYMU22_FUT_CME [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:08:31.503 MYMU22_FUT_CME [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:08:31.541 MYMU22_FUT_CME [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:08:31.588 MYMU22_FUT_CME [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:08:31.644 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:37.088 MYMU22_FUT_CME [CV][M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:37.656 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:37.668 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:39.246 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:40.021 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:40.620 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:43.432 MYMU22_FUT_CME [CV][M] Renko 8t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:08:43.587 Saved Chartbook: Volume Divergence.Cht. Time: 0.0293 seconds. | 2022-09-20 10:08:58.709 MYMU22_FUT_CME [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:10:18.160 MYMU22_FUT_CME [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:10:18.185 MYMU22_FUT_CME [CV][M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:10:21.542 MYMU22_FUT_CME [CV][M] Renko 8t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:10:24.134 Socket (4) | CloseSocket call. | 2022-09-20 10:16:19.739 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:16:19.739 Historical data download thread signaled to stop. | 2022-09-20 10:16:19.739 HD Request # 2 | Received 28893012 Intraday data records from 2022-05-12 13:57:18.019000 to 2022-06-17 09:29:59.827000 (35.8 days) and wrote 28892984 records for MNQM22_FUT_CME | 2022-09-20 10:16:19.740 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:59.827000 | 2022-09-20 10:16:19.741 HD Request # 2 | Completion time: 12m 55s. | 2022-09-20 10:16:19.741 HD Request # 2 | Intraday data download complete for MNQM22_FUT_CME. Unique request ID: 2 | 2022-09-20 10:16:19.741 Removing historical data download ID 2. | 2022-09-20 10:16:19.741 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:16:19.741 Triggering next historical data download in queue. | 2022-09-20 10:16:19.741 HD Request # 5 | Downloading Intraday chart data for MYMU22_FUT_CME to the file MYMU22_FUT_CME.scid. Service: cbot | 2022-09-20 10:16:19.741 HD Request # 5 | Download start date-time: 2022-09-16 09:28:45.000000. File last date-time: 2022-09-16 09:28:45.113000 | 2022-09-20 10:16:19.741 HD Request # 5 | Using server: ds21.sierracharts.com port 10149 | 2022-09-20 10:16:19.742 Socket (3) | Creating socket. | 2022-09-20 10:16:19.742 Socket (3) | New receive buffer size: 5242880 | 2022-09-20 10:16:19.742 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-09-20 10:16:19.742 Socket (4) | Socket gracefully closed by remote side. | 2022-09-20 10:16:19.884 Socket (4) | Closed. | 2022-09-20 10:16:19.885 HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-09-20 10:16:20.104 HD Request # 5 | Sending historical data logon request message. | 2022-09-20 10:16:20.104 HD Request # 5 | Requesting Intraday data. Start date-time: 2022-09-16 09:28:45. Record interval: 0. Symbol: MYMU22 | 2022-09-20 10:16:20.787 HD Request # 5 | Decompressing data. | 2022-09-20 10:16:20.913 HD Request # 5 | Receiving Intraday data for MYMU22_FUT_CME starting at 2022-09-16 09:28:45.113000 | 2022-09-20 10:16:20.913 Socket (3) | CloseSocket call. | 2022-09-20 10:16:20.913 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:16:20.914 Historical data download thread signaled to stop. | 2022-09-20 10:16:20.914 HD Request # 5 | Received 1 Intraday data record from 2022-09-16 09:28:45.113000 to 2022-09-16 09:28:45.113000 (0.0 seconds) and wrote 0 records for MYMU22_FUT_CME | 2022-09-20 10:16:20.914 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:28:45.113000 | 2022-09-20 10:16:20.915 HD Request # 5 | Completion time: 1s. | 2022-09-20 10:16:20.915 HD Request # 5 | Intraday data download complete for MYMU22_FUT_CME. Unique request ID: 4 | 2022-09-20 10:16:20.915 Removing historical data download ID 4. | 2022-09-20 10:16:20.915 Real-time Intraday chart data file updates started for MYMU22_FUT_CME | 2022-09-20 10:16:20.915 Intraday chart data file opened for MYMU22_FUT_CME | 2022-09-20 10:16:20.916 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:16:20.916 Triggering next historical data download in queue. | 2022-09-20 10:16:20.916 HD Request # 6 | Downloading Intraday chart data for MYMM22_FUT_CME to the file MYMM22_FUT_CME.scid. Service: cbot | 2022-09-20 10:16:20.916 HD Request # 6 | Download start date-time: 2022-06-17 09:29:52.000000. File last date-time: 2022-06-17 09:29:52.572000 | 2022-09-20 10:16:20.916 HD Request # 6 | Using server: ds23.sierracharts.com port 10150 | 2022-09-20 10:16:20.916 Socket (4) | Creating socket. | 2022-09-20 10:16:20.916 Socket (4) | New receive buffer size: 5242880 | 2022-09-20 10:16:20.917 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:16:20.917 Socket (3) | Socket gracefully closed by remote side. | 2022-09-20 10:16:21.040 Socket (3) | Closed. | 2022-09-20 10:16:21.040 HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-09-20 10:16:21.195 HD Request # 6 | Sending historical data logon request message. | 2022-09-20 10:16:21.195 HD Request # 6 | Requesting Intraday data. Start date-time: 2022-06-17 09:29:52. Record interval: 0. Symbol: MYMM22 | 2022-09-20 10:16:21.842 HD Request # 6 | Decompressing data. | 2022-09-20 10:16:22.047 HD Request # 6 | Receiving Intraday data for MYMM22_FUT_CME starting at 2022-06-17 09:29:52.572000 | 2022-09-20 10:16:22.047 Socket (4) | CloseSocket call. | 2022-09-20 10:16:22.047 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:16:22.047 Historical data download thread signaled to stop. | 2022-09-20 10:16:22.048 HD Request # 6 | Received 1 Intraday data record from 2022-06-17 09:29:52.572000 to 2022-06-17 09:29:52.572000 (0.0 seconds) and wrote 0 records for MYMM22_FUT_CME | 2022-09-20 10:16:22.048 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:52.572000 | 2022-09-20 10:16:22.049 HD Request # 6 | Completion time: 2s. | 2022-09-20 10:16:22.049 HD Request # 6 | Intraday data download complete for MYMM22_FUT_CME. Unique request ID: 6 | 2022-09-20 10:16:22.049 Removing historical data download ID 6. | 2022-09-20 10:16:22.049 Real-time Intraday chart data file updates started for MYMM22_FUT_CME | 2022-09-20 10:16:22.049 Intraday chart data file opened for MYMM22_FUT_CME | 2022-09-20 10:16:22.049 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:16:22.049 Triggering next historical data download in queue. | 2022-09-20 10:16:22.049 No download requests in the queue to start downloads for. | 2022-09-20 10:16:22.049 Socket (4) | Socket gracefully closed by remote side. | 2022-09-20 10:16:22.172 Socket (4) | Closed. | 2022-09-20 10:16:22.172 MYMU22_FUT_CME [CV] 20 Sec #1 | Reloading chart. | 2022-09-20 10:18:34.383 MYMU22_FUT_CME [CV] 20 Sec #3 | Reloading chart. | 2022-09-20 10:18:34.472 MYMU22_FUT_CME [CV] 20 Sec #2 | Reloading chart. | 2022-09-20 10:18:34.599 MYMU22_FUT_CME [CV] 20 Sec #4 | Reloading chart. | 2022-09-20 10:18:34.689 MYMU22_FUT_CME [CV] 20 Sec #5 | Reloading chart. | 2022-09-20 10:18:34.780 MYMU22_FUT_CME [CV] Renko 10t #6 | Reloading chart. | 2022-09-20 10:18:34.895 MNQU22_FUT_CME [CV] Renko 20t #7 | Reloading chart. | 2022-09-20 10:18:35.252 Mapping MNQU22_FUT_CME to MNQU22. Service code: cme | 2022-09-20 10:18:35.596 SC Data - All Services | Starting real-time market data updates for: MNQU22_FUT_CME (MNQU22). ID: 9 Service code: cme | 2022-09-20 10:18:35.596 SC Data - All Services | Requesting security definition data for: MNQU22_FUT_CME (MNQU22). ID: 9 | 2022-09-20 10:18:35.597 Added historical Intraday data request for MNQU22_FUT_CME to the queue. | 2022-09-20 10:18:35.614 Intraday data recording state for symbol MNQU22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:18:35.614 Triggering next historical data download in queue. | 2022-09-20 10:18:35.614 Delaying start of download for MNQU22_FUT_CME. | 2022-09-20 10:18:35.659 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU22_FUT_CME | 2022-09-20 10:18:35.750 Teton CME Order Routing | Received security definition for symbol MNQU22_FUT_CME | 2022-09-20 10:18:35.750 SC Data - All Services | Real-time data for symbol MNQU22_FUT_CME is currently unavailable. | 2022-09-20 10:18:35.846 SC Data - All Services | Received security definition for symbol MNQU22_FUT_CME | 2022-09-20 10:18:35.846 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:39.630 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:40.827 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:41.398 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:42.255 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:42.912 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:18:46.088 HD Request # 7 | Downloading Intraday chart data for MNQU22_FUT_CME to the file MNQU22_FUT_CME.scid. Service: cme | 2022-09-20 10:18:46.475 HD Request # 7 | Download start date-time: 2022-08-19 04:15:21.000000. File last date-time: 2022-08-19 04:15:21.644002 | 2022-09-20 10:18:46.476 HD Request # 7 | Using server: ds21.sierracharts.com port 10149 | 2022-09-20 10:18:46.476 Socket (3) | Creating socket. | 2022-09-20 10:18:46.476 Socket (3) | New receive buffer size: 5242880 | 2022-09-20 10:18:46.476 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-09-20 10:18:46.476 HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-09-20 10:18:46.897 HD Request # 7 | Sending historical data logon request message. | 2022-09-20 10:18:46.897 HD Request # 7 | Requesting Intraday data. Start date-time: 2022-08-19 04:15:21. Record interval: 0. Symbol: MNQU22 | 2022-09-20 10:18:47.611 HD Request # 7 | Decompressing data. | 2022-09-20 10:18:47.766 HD Request # 7 | Receiving Intraday data for MNQU22_FUT_CME starting at 2022-08-19 04:15:21.449000 | 2022-09-20 10:18:47.777 HD Request # 7 | Timestamp of first Intraday data file record written: 2022-08-19 04:15:22.849000. | 2022-09-20 10:18:48.868 MNQU22_FUT_CME [CV][M] Renko 20t #7 | Reloading chart. | 2022-09-20 10:18:49.996 Socket (3) | Error setting receive buffer size to 10485760. Unknown Windows error code 10055. | 2022-09-20 10:19:17.658 * MNQU22_FUT_CME [CV][M] Renko 20t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:19:34.528 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-09-20 10:23:46.615 DTC Client socket (1) | CloseSocket call. | 2022-09-20 10:23:46.616 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:23:46.616 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-20 10:23:46.616 DTC Client socket (2) | CloseSocket call. | 2022-09-20 10:23:46.616 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:23:46.616 SC Data - All Services | Disconnected from the server. | 2022-09-20 10:23:46.616 Teton CME Order Routing | Disconnected. | 2022-09-20 10:23:46.617 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 3. | 2022-09-20 10:23:46.695 Current selected Data/Trading service: SC Data - All Services | 2022-09-20 10:23:46.695 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-09-20 10:23:46.742 DTC Client socket (2) | Closed. | 2022-09-20 10:23:46.742 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-20 10:23:46.766 DTC Client socket (1) | Closed. | 2022-09-20 10:23:46.766 Symbol settings MD5 received. Request ID: 3. | 2022-09-20 10:23:48.538 Requested symbol settings for service code scdataallservices. Request ID: 4. | 2022-09-20 10:23:48.538 Symbol settings received. Request ID: 4. | 2022-09-20 10:23:50.852 SC Data - All Services | Disconnected. | 2022-09-20 10:23:52.511 SC Data - All Services | Disconnected. | 2022-09-20 10:23:52.518 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-20 10:23:52.518 MYMU22-CBOT [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:23:52.838 MYMU22-CBOT [CV][M] 60 Min #4 | Performing continuous chart historical Daily data download for symbol MYMU22-CBOT starting at last date in file. | 2022-09-20 10:23:52.842 Added historical Daily data request for MYMU22-CBOT to the queue. | 2022-09-20 10:23:52.842 Triggering next historical data download in queue. | 2022-09-20 10:23:52.842 MYMU22-CBOT [CV][M] 60 Min #4 | Waiting for historical downloads to complete with the IDs: 8, | 2022-09-20 10:23:52.851 Mapping MYMU22-CBOT to MYMU22. Service code: cbot | 2022-09-20 10:23:52.853 HD Request # 8 | Downloading Historical Daily chart data for MYMU22-CBOT. Starting date: 2022-08-15. Service: scdataallservices | 2022-09-20 10:23:52.854 MYMU22-CBOT [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:23:52.880 MYMU22-CBOT [CV][M] 20 Sec #4 | Waiting for historical downloads to complete with the IDs: 8, | 2022-09-20 10:23:52.892 MYMU22-CBOT [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:23:52.905 MYMU22-CBOT [CV][M] 20 Sec #2 | Waiting for historical downloads to complete with the IDs: 8, | 2022-09-20 10:23:52.917 MYMU22-CBOT [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:23:52.923 MYMU22-CBOT [CV][M] 20 Sec #1 | Waiting for historical downloads to complete with the IDs: 8, | 2022-09-20 10:23:52.935 MYMU22-CBOT [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:23:52.943 MYMU22-CBOT [CV][M] 20 Sec #5 | Waiting for historical downloads to complete with the IDs: 8, | 2022-09-20 10:23:52.953 MYMM22-CBOT [CV][M] Renko 10t #1 | Reloading chart. | 2022-09-20 10:23:52.955 MYMM22-CBOT [CV][M] Renko 10t #1 | Performing continuous chart historical Daily data download for symbol MYMM22-CBOT starting at last date in file. | 2022-09-20 10:23:52.956 Added historical Daily data request for MYMM22-CBOT to the queue. | 2022-09-20 10:23:52.956 Triggering next historical data download in queue. | 2022-09-20 10:23:52.956 MYMM22-CBOT [CV][M] Renko 10t #1 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:52.961 MYMU22-CBOT [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:23:53.022 MYMU22-CBOT [CV][M] Renko 8t #3 | Waiting for historical downloads to complete with the IDs: 8, 9, | 2022-09-20 10:23:53.033 MYMM22-CBOT [CV][M] Renko 10t #2 | Reloading chart. | 2022-09-20 10:23:53.042 MYMM22-CBOT [CV][M] Renko 10t #2 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:53.048 MYMU22-CBOT [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:23:53.056 MYMU22-CBOT [CV][M] 20 Sec #3 | Waiting for historical downloads to complete with the IDs: 8, 9, | 2022-09-20 10:23:53.068 MYMU22-CBOT [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:23:53.071 MYMU22-CBOT [CV][M] Renko 10t #6 | Waiting for historical downloads to complete with the IDs: 8, 9, | 2022-09-20 10:23:53.083 MNQU22-CME [CV][M] Renko 20t #7 | Reloading chart. | 2022-09-20 10:23:53.092 MNQU22-CME [CV][M] Renko 20t #7 | Performing continuous chart historical Daily data download for symbol MNQU22-CME starting at last date in file. | 2022-09-20 10:23:53.096 Added historical Daily data request for MNQU22-CME to the queue. | 2022-09-20 10:23:53.096 Triggering next historical data download in queue. | 2022-09-20 10:23:53.096 MNQU22-CME [CV][M] Renko 20t #7 | Waiting for historical downloads to complete with the IDs: 10, | 2022-09-20 10:23:53.107 HD Request # 8 | Requesting historical Daily data for YRU22 starting at 2022-08-14. SC External HD service. | 2022-09-20 10:23:53.300 HD Request # 8 | Receiving historical Daily data for MYMU22-CBOT starting at 2022-08-15. | 2022-09-20 10:23:53.842 HD Request # 8 | Writing historical Daily data to the file MYMU22-CBOT.dly. | 2022-09-20 10:23:53.843 HD Request # 8 | Bytes received: 1279 | 2022-09-20 10:23:53.844 HD Request # 8 | Received 24 Daily data records from 2022-08-15 00:00:00 to 2022-09-16 00:00:00 (33.0 days) and wrote 24 records for MYMU22-CBOT | 2022-09-20 10:23:53.844 HD Request # 8 | Completion time: 1s. | 2022-09-20 10:23:53.844 HD Request # 8 | Daily data download complete for MYMU22-CBOT. Unique request ID: 8 | 2022-09-20 10:23:53.844 Removing historical data download ID 8. | 2022-09-20 10:23:53.844 Triggering next historical data download in queue. | 2022-09-20 10:23:53.844 Mapping MYMM22-CBOT to MYMM22. Service code: cbot | 2022-09-20 10:23:53.844 HD Request # 9 | Downloading Historical Daily chart data for MYMM22-CBOT. Starting date: 2022-06-15. Service: scdataallservices | 2022-09-20 10:23:53.845 MYMU22-CBOT [CV][M] 20 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:53.849 MYMU22-CBOT [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:23:53.849 MYMU22-CBOT [CV][M] 20 Sec #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:53.857 MYMU22-CBOT [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:23:53.863 MYMU22-CBOT [CV][M] 20 Sec #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:53.871 MYMU22-CBOT [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:23:53.873 MYMU22-CBOT [CV][M] 60 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:53.883 MYMU22-CBOT [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:23:53.885 MYMU22-CBOT [CV][M] 20 Sec #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:53.900 MYMU22-CBOT [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:23:53.902 MYMU22-CBOT [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:23:53.920 MYMU22-CBOT [CV][M] 20 Sec #5 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:53.943 MYMU22-CBOT [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:23:53.947 MYMU22-CBOT [CV][M] 20 Sec #1 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:53.968 MYMU22-CBOT [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:23:53.971 MYMU22-CBOT [CV][M] 20 Sec #2 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:53.995 MYMU22-CBOT [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:23:53.998 MYMU22-CBOT [CV][M] 60 Min #4 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:54.023 MYMU22-CBOT [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:23:54.032 MYMU22-CBOT [CV][M] 20 Sec #4 | Waiting for historical downloads to complete with the IDs: 9, | 2022-09-20 10:23:54.054 HD Request # 9 | Requesting historical Daily data for YRM22 starting at 2022-06-14. SC External HD service. | 2022-09-20 10:23:54.274 SC Data - All Services | Connected to server complete. | 2022-09-20 10:23:54.520 Triggering next historical data download in queue. | 2022-09-20 10:23:54.520 Triggering next historical data download in queue. | 2022-09-20 10:23:54.520 Triggering next historical data download in queue. | 2022-09-20 10:23:54.520 Triggering next historical data download in queue. | 2022-09-20 10:23:54.520 Subscribing to symbol for symbol alert. NQM18-CME | 2022-09-20 10:23:54.520 Mapping NQM18-CME to NQM18. Service code: cme | 2022-09-20 10:23:54.521 Using symbol data fast lookup vector | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: NQM18-CME (NQM18). ID: 1 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: NQM18-CME (NQM18). ID: 1 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM18-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM18-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM18-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM18-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Mapping NQM19-CME to NQM19. Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: NQM19-CME (NQM19). ID: 2 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: NQM19-CME (NQM19). ID: 2 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQM19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Mapping NQU19-CME to NQU19. Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: NQU19-CME (NQU19). ID: 3 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: NQU19-CME (NQU19). ID: 3 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Mapping MNQU19-CME to MNQU19. Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: MNQU19-CME (MNQU19). ID: 4 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: MNQU19-CME (MNQU19). ID: 4 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. NQU19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQZ19-CME | 2022-09-20 10:23:54.521 Mapping MNQZ19-CME to MNQZ19. Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: MNQZ19-CME (MNQZ19). ID: 5 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: MNQZ19-CME (MNQZ19). ID: 5 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQZ19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQZ19-CME | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQH20-CME | 2022-09-20 10:23:54.521 Mapping MNQH20-CME to MNQH20. Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Starting real-time market data updates for: MNQH20-CME (MNQH20). ID: 6 Service code: cme | 2022-09-20 10:23:54.521 SC Data - All Services | Requesting security definition data for: MNQH20-CME (MNQH20). ID: 6 | 2022-09-20 10:23:54.521 Subscribing to symbol for symbol alert. MNQH20-CME | 2022-09-20 10:23:54.521 No download requests in the queue to start downloads for. | 2022-09-20 10:23:54.522 No download requests in the queue to start downloads for. | 2022-09-20 10:23:54.522 DTC Client socket (4) | Creating socket. | 2022-09-20 10:23:54.565 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-09-20 10:23:54.566 DTC Client socket (4) | Connecting to IP: 208.185.224.128. | 2022-09-20 10:23:54.566 HD Request # 9 | Receiving historical Daily data for MYMM22-CBOT starting at 2022-06-15. | 2022-09-20 10:23:54.568 HD Request # 9 | Writing historical Daily data to the file MYMM22-CBOT.dly. | 2022-09-20 10:23:54.569 HD Request # 9 | Bytes received: 207 | 2022-09-20 10:23:54.571 HD Request # 9 | Received 4 Daily data records from 2022-06-15 00:00:00 to 2022-06-17 00:00:00 (3.0 days) and wrote 3 records for MYMM22-CBOT | 2022-09-20 10:23:54.571 HD Request # 9 | Completion time: 1s. | 2022-09-20 10:23:54.571 HD Request # 9 | Daily data download complete for MYMM22-CBOT. Unique request ID: 9 | 2022-09-20 10:23:54.571 Removing historical data download ID 9. | 2022-09-20 10:23:54.571 Triggering next historical data download in queue. | 2022-09-20 10:23:54.571 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-09-20 10:23:54.571 HD Request # 10 | Downloading Historical Daily chart data for MNQU22-CME. Starting date: 2022-08-15. Service: scdataallservices | 2022-09-20 10:23:54.573 MYMU22-CBOT [CV][M] 20 Sec #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.573 MYMU22-CBOT [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:23:54.575 MYMU22-CBOT [CV][M] 60 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.579 MYMU22-CBOT [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:23:54.580 MYMU22-CBOT [CV][M] 20 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.587 MYMU22-CBOT [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:23:54.589 MYMU22-CBOT [CV][M] Renko 10t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.595 MYMU22-CBOT [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:23:54.596 MYMU22-CBOT [CV][M] 20 Sec #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.609 MYMU22-CBOT [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:23:54.613 MYMM22-CBOT [CV][M] Renko 10t #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.617 MYMM22-CBOT [CV][M] Renko 10t #2 | Reloading chart. | 2022-09-20 10:23:54.619 MYMU22-CBOT [CV][M] 20 Sec #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.633 MYMU22-CBOT [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:23:54.643 MYMM22-CBOT [CV][M] Renko 10t #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.662 MYMM22-CBOT [CV][M] Renko 10t #1 | Reloading chart. | 2022-09-20 10:23:54.674 MYMU22-CBOT [CV][M] Renko 8t #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.722 MYMU22-CBOT [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:23:54.744 SC Data - All Services | Network connection to server complete. | 2022-09-20 10:23:54.818 SC Data - All Services | Starting socket receive thread. | 2022-09-20 10:23:54.821 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-20 10:23:54.821 MYMU22-CBOT [CV][M] 20 Sec #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:54.848 MYMU22-CBOT [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:23:54.849 HD Request # 10 | Requesting historical Daily data for NMU22 starting at 2022-08-14. SC External HD service. | 2022-09-20 10:23:55.040 MYMU22-CBOT [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:23:55.066 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-20 10:23:55.087 SC Data - All Services | Sending logon request message. | 2022-09-20 10:23:55.087 MYMU22-CBOT [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:23:55.102 MYMU22-CBOT [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:23:55.196 MYMU22-CBOT [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:23:55.240 HD Request # 10 | Receiving historical Daily data for MNQU22-CME starting at 2022-08-15. | 2022-09-20 10:23:55.286 HD Request # 10 | Writing historical Daily data to the file MNQU22-CME.dly. | 2022-09-20 10:23:55.287 HD Request # 10 | Bytes received: 1500 | 2022-09-20 10:23:55.290 HD Request # 10 | Received 24 Daily data records from 2022-08-15 00:00:00 to 2022-09-16 00:00:00 (33.0 days) and wrote 24 records for MNQU22-CME | 2022-09-20 10:23:55.290 HD Request # 10 | Completion time: 1s. | 2022-09-20 10:23:55.291 HD Request # 10 | Daily data download complete for MNQU22-CME. Unique request ID: 10 | 2022-09-20 10:23:55.291 Removing historical data download ID 10. | 2022-09-20 10:23:55.291 Triggering next historical data download in queue. | 2022-09-20 10:23:55.293 No download requests in the queue to start downloads for. | 2022-09-20 10:23:55.294 MYMU22-CBOT [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:23:55.307 MYMM22-CBOT [CV][M] Renko 10t #2 | Reloading chart. | 2022-09-20 10:23:55.390 MNQU22-CME [CV][M] Renko 20t #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-20 10:23:55.430 MNQU22-CME [CV][M] Renko 20t #7 | Reloading chart. | 2022-09-20 10:23:55.431 MYMU22-CBOT [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:23:55.447 MYMM22-CBOT [CV][M] Renko 10t #1 | Reloading chart. | 2022-09-20 10:23:55.481 MYMU22-CBOT [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:23:55.507 MYMU22-CBOT [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:23:55.611 Mapping MYMU22-CBOT to MYMU22. Service code: cbot | 2022-09-20 10:23:55.657 SC Data - All Services | Starting real-time market data updates for: MYMU22-CBOT (MYMU22). ID: 8 Service code: cbot | 2022-09-20 10:23:55.657 SC Data - All Services | Requesting security definition data for: MYMU22-CBOT (MYMU22). ID: 8 | 2022-09-20 10:23:55.657 Added historical Intraday data request for MYMU22-CBOT to the queue. | 2022-09-20 10:23:55.657 Intraday data recording state for symbol MYMU22-CBOT is set to download 'Pending'. | 2022-09-20 10:23:55.657 Triggering next historical data download in queue. | 2022-09-20 10:23:55.657 Mapping MYMM22-CBOT to MYMM22. Service code: cbot | 2022-09-20 10:23:55.739 SC Data - All Services | Starting real-time market data updates for: MYMM22-CBOT (MYMM22). ID: 9 Service code: cbot | 2022-09-20 10:23:55.739 SC Data - All Services | Requesting security definition data for: MYMM22-CBOT (MYMM22). ID: 9 | 2022-09-20 10:23:55.739 Added historical Intraday data request for MYMM22-CBOT to the queue. | 2022-09-20 10:23:55.740 Intraday data recording state for symbol MYMM22-CBOT is set to download 'Pending'. | 2022-09-20 10:23:55.740 Triggering next historical data download in queue. | 2022-09-20 10:23:55.740 MNQU22-CME [CV][M] Renko 20t #7 | Reloading chart. | 2022-09-20 10:23:55.760 SC Data - All Services | Received logon response. | 2022-09-20 10:23:55.942 SC Data - All Services | Server Name: SC Realtime Server. | 2022-09-20 10:23:55.942 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:23:55.942 SC Data - All Services | Successfully connected. | 2022-09-20 10:23:55.942 SC Data - All Services | Trading is not supported. | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: MNQH20-CME -> MNQH20 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: MNQU19-CME -> MNQU19 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: MNQZ19-CME -> MNQZ19 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: MYMM22-CBOT -> MYMM22 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: MYMU22-CBOT -> MYMU22 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: NQM18-CME -> NQM18 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: NQM19-CME -> NQM19 | 2022-09-20 10:23:55.942 SC Data - All Services | Restarting real-time data updates for symbol: NQU19-CME -> NQU19 | 2022-09-20 10:23:55.942 SC Data - All Services | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 7 Service code: cme | 2022-09-20 10:23:55.998 SC Data - All Services | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 7 | 2022-09-20 10:23:55.998 Added historical Intraday data request for MNQU22-CME to the queue. | 2022-09-20 10:23:55.998 Intraday data recording state for symbol MNQU22-CME is set to download 'Pending'. | 2022-09-20 10:23:55.998 Triggering next historical data download in queue. | 2022-09-20 10:23:55.999 SC Data - All Services | Real-time data for symbol MNQH20-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MNQH20-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol MNQU19-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MNQU19-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol MNQZ19-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MNQZ19-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol MYMM22-CBOT is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MYMM22-CBOT | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol MYMU22-CBOT is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MYMU22-CBOT | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol NQM18-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol NQM18-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol NQM19-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol NQM19-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol NQU19-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol NQU19-CME | 2022-09-20 10:23:56.262 SC Data - All Services | Real-time data for symbol MNQU22-CME is currently unavailable. | 2022-09-20 10:23:56.262 SC Data - All Services | Received security definition for symbol MNQU22-CME | 2022-09-20 10:23:56.262 MYMM22-CBOT [CV][M] Renko 10t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:23:57.666 MYMM22-CBOT [CV][M] Renko 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:23:57.909 MYMU22-CBOT [CV][M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:00.964 MYMU22-CBOT [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:01.064 MYMU22-CBOT [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:01.801 MYMU22-CBOT [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:02.720 MYMU22-CBOT [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:03.357 MYMU22-CBOT [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:07.061 MYMU22-CBOT [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:08.154 MYMU22-CBOT [CV][M] Renko 8t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:08.325 Socket (3) | CloseSocket call. | 2022-09-20 10:24:51.064 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:24:51.065 Historical data download thread signaled to stop. | 2022-09-20 10:24:51.065 HD Request # 7 | Received 19281843 Intraday data records from 2022-08-19 04:15:21.449000 to 2022-09-16 09:29:57.257000 (28.2 days) and wrote 19281839 records for MNQU22_FUT_CME | 2022-09-20 10:24:51.065 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:57.257000 | 2022-09-20 10:24:51.066 HD Request # 7 | Completion time: 6m 5s. | 2022-09-20 10:24:51.066 HD Request # 7 | Intraday data download complete for MNQU22_FUT_CME. Unique request ID: 7 | 2022-09-20 10:24:51.066 Removing historical data download ID 7. | 2022-09-20 10:24:51.066 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:24:51.066 Triggering next historical data download in queue. | 2022-09-20 10:24:51.066 HD Request # 11 | Downloading Intraday chart data for MYMU22-CBOT to the file MYMU22-CBOT.scid. Service: cbot | 2022-09-20 10:24:51.066 HD Request # 11 | Download start date-time: 2022-08-18 14:11:55.000000. File last date-time: 2022-08-18 14:11:55.052000 | 2022-09-20 10:24:51.066 HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2022-09-20 10:24:51.066 Socket (2) | Creating socket. | 2022-09-20 10:24:51.067 Socket (2) | New receive buffer size: 5242880 | 2022-09-20 10:24:51.067 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:24:51.067 Socket (3) | Socket gracefully closed by remote side. | 2022-09-20 10:24:51.202 Socket (3) | Closed. | 2022-09-20 10:24:51.202 HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-09-20 10:24:51.399 HD Request # 11 | Sending historical data logon request message. | 2022-09-20 10:24:51.399 HD Request # 11 | Requesting Intraday data. Start date-time: 2022-08-18 14:11:55. Record interval: 0. Symbol: MYMU22 | 2022-09-20 10:24:52.084 HD Request # 11 | Decompressing data. | 2022-09-20 10:24:52.221 HD Request # 11 | Receiving Intraday data for MYMU22-CBOT starting at 2022-08-18 14:11:55.052000 | 2022-09-20 10:24:52.241 HD Request # 11 | Timestamp of first Intraday data file record written: 2022-08-18 14:11:57.082000. | 2022-09-20 10:24:53.443 MNQU22-CME [CV][M] Renko 20t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:24:53.639 Socket (2) | CloseSocket call. | 2022-09-20 10:25:18.436 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:25:18.436 Historical data download thread signaled to stop. | 2022-09-20 10:25:18.437 HD Request # 11 | Received 1795956 Intraday data records from 2022-08-18 14:11:55.052000 to 2022-09-16 09:28:45.113000 (28.8 days) and wrote 1795955 records for MYMU22-CBOT | 2022-09-20 10:25:18.437 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:28:45.113000 | 2022-09-20 10:25:18.437 HD Request # 11 | Completion time: 27s. | 2022-09-20 10:25:18.437 HD Request # 11 | Intraday data download complete for MYMU22-CBOT. Unique request ID: 11 | 2022-09-20 10:25:18.437 Removing historical data download ID 11. | 2022-09-20 10:25:18.437 Real-time Intraday chart data file updates started for MYMU22-CBOT | 2022-09-20 10:25:18.437 Intraday chart data file opened for MYMU22-CBOT | 2022-09-20 10:25:18.437 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:25:18.437 Triggering next historical data download in queue. | 2022-09-20 10:25:18.437 HD Request # 12 | Downloading Intraday chart data for MYMM22-CBOT to the file MYMM22-CBOT.scid. Service: cbot | 2022-09-20 10:25:18.437 HD Request # 12 | Download start date-time: 2022-06-17 09:29:52.000000. File last date-time: 2022-06-17 09:29:52.572000 | 2022-09-20 10:25:18.438 HD Request # 12 | Using server: ds21.sierracharts.com port 10149 | 2022-09-20 10:25:18.438 Socket (1) | Creating socket. | 2022-09-20 10:25:18.439 Socket (1) | New receive buffer size: 5242880 | 2022-09-20 10:25:18.439 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-09-20 10:25:18.439 Socket (2) | Socket gracefully closed by remote side. | 2022-09-20 10:25:18.633 Socket (2) | Closed. | 2022-09-20 10:25:18.633 HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-09-20 10:25:18.833 HD Request # 12 | Sending historical data logon request message. | 2022-09-20 10:25:18.833 HD Request # 12 | Requesting Intraday data. Start date-time: 2022-06-17 09:29:52. Record interval: 0. Symbol: MYMM22 | 2022-09-20 10:25:19.504 HD Request # 12 | Decompressing data. | 2022-09-20 10:25:19.644 HD Request # 12 | Receiving Intraday data for MYMM22-CBOT starting at 2022-06-17 09:29:52.572000 | 2022-09-20 10:25:19.645 Socket (1) | CloseSocket call. | 2022-09-20 10:25:19.645 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:25:19.646 Historical data download thread signaled to stop. | 2022-09-20 10:25:19.646 HD Request # 12 | Received 1 Intraday data record from 2022-06-17 09:29:52.572000 to 2022-06-17 09:29:52.572000 (0.0 seconds) and wrote 0 records for MYMM22-CBOT | 2022-09-20 10:25:19.646 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:52.572000 | 2022-09-20 10:25:19.651 HD Request # 12 | Completion time: 1s. | 2022-09-20 10:25:19.651 HD Request # 12 | Intraday data download complete for MYMM22-CBOT. Unique request ID: 12 | 2022-09-20 10:25:19.651 Removing historical data download ID 12. | 2022-09-20 10:25:19.651 Real-time Intraday chart data file updates started for MYMM22-CBOT | 2022-09-20 10:25:19.651 Intraday chart data file opened for MYMM22-CBOT | 2022-09-20 10:25:19.651 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:25:19.651 Triggering next historical data download in queue. | 2022-09-20 10:25:19.651 HD Request # 13 | Downloading Intraday chart data for MNQU22-CME to the file MNQU22-CME.scid. Service: cme | 2022-09-20 10:25:19.652 HD Request # 13 | Download start date-time: 2022-08-18 14:11:55.000000. File last date-time: 2022-08-18 14:11:55.502000 | 2022-09-20 10:25:19.653 HD Request # 13 | Using server: ds23.sierracharts.com port 10150 | 2022-09-20 10:25:19.654 Socket (2) | Creating socket. | 2022-09-20 10:25:19.654 Socket (2) | New receive buffer size: 5242880 | 2022-09-20 10:25:19.655 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:25:19.655 Socket (1) | Socket gracefully closed by remote side. | 2022-09-20 10:25:19.771 Socket (1) | Closed. | 2022-09-20 10:25:19.771 HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-09-20 10:25:19.923 HD Request # 13 | Sending historical data logon request message. | 2022-09-20 10:25:19.923 HD Request # 13 | Requesting Intraday data. Start date-time: 2022-08-18 14:11:55. Record interval: 0. Symbol: MNQU22 | 2022-09-20 10:25:20.045 HD Request # 13 | Decompressing data. | 2022-09-20 10:25:20.173 HD Request # 13 | Receiving Intraday data for MNQU22-CME starting at 2022-08-18 14:11:55.231000 | 2022-09-20 10:25:20.192 HD Request # 13 | Timestamp of first Intraday data file record written: 2022-08-18 14:11:56.024000. | 2022-09-20 10:25:21.264 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-20 10:25:52.074 DTC Client socket (4) | CloseSocket call. | 2022-09-20 10:25:52.075 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:25:52.075 SC Data - All Services | Disconnected from the server. | 2022-09-20 10:25:52.075 SC Data - All Services | Disconnected. | 2022-09-20 10:25:52.075 SC Data - All Services | Disconnected. | 2022-09-20 10:25:52.122 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 5. | 2022-09-20 10:25:52.132 Current selected Data/Trading service: Teton CME Order Routing | 2022-09-20 10:25:52.132 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-09-20 10:25:52.220 DTC Client socket (4) | Closed. | 2022-09-20 10:25:52.220 Symbol settings MD5 received. Request ID: 5. | 2022-09-20 10:25:53.554 Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 6. | 2022-09-20 10:25:53.554 Symbol settings received. Request ID: 6. | 2022-09-20 10:25:55.551 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-20 10:25:57.477 MNQU22_FUT_CME [CV][M] Renko 20t #7 | Reloading chart. | 2022-09-20 10:25:57.767 MYMU22_FUT_CME [CV][M] Renko 10t #6 | Reloading chart. | 2022-09-20 10:25:57.800 MYMM22_FUT_CME [CV][M] Renko 10t #2 | Reloading chart. | 2022-09-20 10:25:57.855 MYMM22_FUT_CME [CV][M] Renko 10t #1 | Reloading chart. | 2022-09-20 10:25:57.885 MYMU22_FUT_CME [CV][M] 20 Sec #3 | Reloading chart. | 2022-09-20 10:25:57.932 MYMU22_FUT_CME [CV][M] 60 Min #4 | Reloading chart. | 2022-09-20 10:25:57.978 MYMU22_FUT_CME [CV][M] 20 Sec #1 | Reloading chart. | 2022-09-20 10:25:58.034 MYMU22_FUT_CME [CV][M] 20 Sec #5 | Reloading chart. | 2022-09-20 10:25:58.108 MYMU22_FUT_CME [CV][M] 20 Sec #4 | Reloading chart. | 2022-09-20 10:25:58.238 MYMU22_FUT_CME [CV][M] Renko 8t #3 | Reloading chart. | 2022-09-20 10:25:58.398 MYMU22_FUT_CME [CV][M] 20 Sec #2 | Reloading chart. | 2022-09-20 10:25:58.551 Mapping MNQU22_FUT_CME to MNQU22. Service code: cme | 2022-09-20 10:25:58.638 Added historical Intraday data request for MNQU22_FUT_CME to the queue. | 2022-09-20 10:25:58.638 Intraday data recording state for symbol MNQU22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:25:58.638 Triggering next historical data download in queue. | 2022-09-20 10:25:58.638 Mapping MYMU22_FUT_CME to MYMU22. Service code: cbot | 2022-09-20 10:25:58.639 Added historical Intraday data request for MYMU22_FUT_CME to the queue. | 2022-09-20 10:25:58.639 Intraday data recording state for symbol MYMU22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:25:58.639 Triggering next historical data download in queue. | 2022-09-20 10:25:58.639 Mapping MYMM22_FUT_CME to MYMM22. Service code: cbot | 2022-09-20 10:25:58.670 Added historical Intraday data request for MYMM22_FUT_CME to the queue. | 2022-09-20 10:25:58.670 Intraday data recording state for symbol MYMM22_FUT_CME is set to download 'Pending'. | 2022-09-20 10:25:58.670 Triggering next historical data download in queue. | 2022-09-20 10:25:58.670 Teton CME Order Routing | Firm: Dorman | 2022-09-20 10:25:59.749 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-09-20 10:25:59.749 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-09-20 10:25:59.833 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-20 10:25:59.833 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-09-20 10:25:59.833 Teton CME Order Routing | Network connection to server complete. | 2022-09-20 10:25:59.986 Teton CME Order Routing | Starting socket receive thread. | 2022-09-20 10:25:59.986 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-09-20 10:25:59.987 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-09-20 10:26:00.452 Teton CME Order Routing | Sending logon request message. | 2022-09-20 10:26:00.452 MYMM22_FUT_CME [CV][M] Renko 10t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:01.004 Teton CME Order Routing | Received logon response. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:26:01.200 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Trading is supported. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Order cancel and replace is supported. | 2022-09-20 10:26:01.200 Teton CME Order Routing | OCO Orders supported. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Bracket Orders supported. | 2022-09-20 10:26:01.200 Teton CME Order Routing | Connected to server complete. | 2022-09-20 10:26:01.200 Triggering next historical data download in queue. | 2022-09-20 10:26:01.201 Triggering next historical data download in queue. | 2022-09-20 10:26:01.201 Triggering next historical data download in queue. | 2022-09-20 10:26:01.201 Triggering next historical data download in queue. | 2022-09-20 10:26:01.201 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:26:01.201 Mapping NQM18_FUT_CME to NQM18. Service code: cme | 2022-09-20 10:26:01.201 Using symbol data fast lookup vector | 2022-09-20 10:26:01.201 SC Data - All Services | Starting real-time market data updates for: NQM18_FUT_CME (NQM18). ID: 1 Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-09-20 10:26:01.202 SC Data - All Services | Requesting security definition data for: NQM18_FUT_CME (NQM18). ID: 1 | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM18_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Mapping NQM19_FUT_CME to NQM19. Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Starting real-time market data updates for: NQM19_FUT_CME (NQM19). ID: 2 Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Requesting security definition data for: NQM19_FUT_CME (NQM19). ID: 2 | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQM19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Mapping NQU19_FUT_CME to NQU19. Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Starting real-time market data updates for: NQU19_FUT_CME (NQU19). ID: 3 Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Requesting security definition data for: NQU19_FUT_CME (NQU19). ID: 3 | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.202 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.202 Mapping MNQU19_FUT_CME to MNQU19. Service code: cme | 2022-09-20 10:26:01.202 SC Data - All Services | Starting real-time market data updates for: MNQU19_FUT_CME (MNQU19). ID: 4 Service code: cme | 2022-09-20 10:26:01.203 SC Data - All Services | Requesting security definition data for: MNQU19_FUT_CME (MNQU19). ID: 4 | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. NQU19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:26:01.203 Mapping MNQZ19_FUT_CME to MNQZ19. Service code: cme | 2022-09-20 10:26:01.203 SC Data - All Services | Starting real-time market data updates for: MNQZ19_FUT_CME (MNQZ19). ID: 5 Service code: cme | 2022-09-20 10:26:01.203 SC Data - All Services | Requesting security definition data for: MNQZ19_FUT_CME (MNQZ19). ID: 5 | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQZ19_FUT_CME | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:26:01.203 Mapping MNQH20_FUT_CME to MNQH20. Service code: cme | 2022-09-20 10:26:01.203 SC Data - All Services | Starting real-time market data updates for: MNQH20_FUT_CME (MNQH20). ID: 6 Service code: cme | 2022-09-20 10:26:01.203 SC Data - All Services | Requesting security definition data for: MNQH20_FUT_CME (MNQH20). ID: 6 | 2022-09-20 10:26:01.203 Subscribing to symbol for symbol alert. MNQH20_FUT_CME | 2022-09-20 10:26:01.203 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-09-20 10:26:01.205 No download requests in the queue to start downloads for. | 2022-09-20 10:26:01.205 No download requests in the queue to start downloads for. | 2022-09-20 10:26:01.205 No download requests in the queue to start downloads for. | 2022-09-20 10:26:01.205 DTC Client socket (3) | Creating socket. | 2022-09-20 10:26:01.212 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-09-20 10:26:01.213 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-09-20 10:26:01.213 Mapping MYMM22_FUT_CME to MYMM22. Service code: cbot | 2022-09-20 10:26:01.221 SC Data - All Services | Starting real-time market data updates for: MYMM22_FUT_CME (MYMM22). ID: 7 Service code: cbot | 2022-09-20 10:26:01.221 SC Data - All Services | Requesting security definition data for: MYMM22_FUT_CME (MYMM22). ID: 7 | 2022-09-20 10:26:01.221 Mapping MYMU22_FUT_CME to MYMU22. Service code: cbot | 2022-09-20 10:26:01.278 SC Data - All Services | Starting real-time market data updates for: MYMU22_FUT_CME (MYMU22). ID: 8 Service code: cbot | 2022-09-20 10:26:01.278 SC Data - All Services | Requesting security definition data for: MYMU22_FUT_CME (MYMU22). ID: 8 | 2022-09-20 10:26:01.278 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM18_FUT_CME | 2022-09-20 10:26:01.362 Teton CME Order Routing | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:26:01.362 Mapping MNQU22_FUT_CME to MNQU22. Service code: cme | 2022-09-20 10:26:01.374 SC Data - All Services | Starting real-time market data updates for: MNQU22_FUT_CME (MNQU22). ID: 9 Service code: cme | 2022-09-20 10:26:01.374 SC Data - All Services | Requesting security definition data for: MNQU22_FUT_CME (MNQU22). ID: 9 | 2022-09-20 10:26:01.374 SC Data - All Services | Network connection to server complete. | 2022-09-20 10:26:01.374 SC Data - All Services | Starting socket receive thread. | 2022-09-20 10:26:01.374 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-20 10:26:01.374 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM19_FUT_CME | 2022-09-20 10:26:01.398 Teton CME Order Routing | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:26:01.399 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQU19_FUT_CME | 2022-09-20 10:26:01.400 Teton CME Order Routing | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:26:01.401 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU19_FUT_CME | 2022-09-20 10:26:01.412 Teton CME Order Routing | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:26:01.412 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ19_FUT_CME | 2022-09-20 10:26:01.412 Teton CME Order Routing | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:26:01.412 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH20_FUT_CME | 2022-09-20 10:26:01.412 Teton CME Order Routing | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:26:01.412 Updated verified funded futures trading account ending date to: 2022-10-20 14:26:01 | 2022-09-20 10:26:01.412 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMM22_FUT_CME | 2022-09-20 10:26:01.412 Teton CME Order Routing | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:26:01.412 MYMM22_FUT_CME [CV][M] Renko 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:01.427 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMU22_FUT_CME | 2022-09-20 10:26:01.623 Teton CME Order Routing | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:26:01.623 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQU22_FUT_CME | 2022-09-20 10:26:01.623 Teton CME Order Routing | Received security definition for symbol MNQU22_FUT_CME | 2022-09-20 10:26:01.623 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-20 10:26:01.623 SC Data - All Services | Sending logon request message. | 2022-09-20 10:26:01.623 SC Data - All Services | Received logon response. | 2022-09-20 10:26:02.573 SC Data - All Services | Server Name: SC Realtime Server. | 2022-09-20 10:26:02.573 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-20 10:26:02.573 SC Data - All Services | Successfully connected. | 2022-09-20 10:26:02.573 SC Data - All Services | Trading is not supported. | 2022-09-20 10:26:02.573 SC Data - All Services | Restarting real-time data updates for symbol: MNQH20_FUT_CME -> MNQH20 | 2022-09-20 10:26:02.601 SC Data - All Services | Restarting real-time data updates for symbol: MNQU19_FUT_CME -> MNQU19 | 2022-09-20 10:26:02.601 SC Data - All Services | Restarting real-time data updates for symbol: MNQU22_FUT_CME -> MNQU22 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: MNQZ19_FUT_CME -> MNQZ19 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: MYMM22_FUT_CME -> MYMM22 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: MYMU22_FUT_CME -> MYMU22 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: NQM18_FUT_CME -> NQM18 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: NQM19_FUT_CME -> NQM19 | 2022-09-20 10:26:02.602 SC Data - All Services | Restarting real-time data updates for symbol: NQU19_FUT_CME -> NQU19 | 2022-09-20 10:26:02.602 SC Data - All Services | Real-time data for symbol MNQH20_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MNQH20_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol MNQU19_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MNQU19_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol MNQU22_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MNQU22_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol MNQZ19_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MNQZ19_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol MYMM22_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MYMM22_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol MYMU22_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol MYMU22_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol NQM18_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol NQM18_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol NQM19_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol NQM19_FUT_CME | 2022-09-20 10:26:02.923 SC Data - All Services | Real-time data for symbol NQU19_FUT_CME is currently unavailable. | 2022-09-20 10:26:02.923 SC Data - All Services | Received security definition for symbol NQU19_FUT_CME | 2022-09-20 10:26:02.923 MYMU22_FUT_CME [CV][M] 60 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:05.162 MYMU22_FUT_CME [CV][M] 20 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:05.259 MYMU22_FUT_CME [CV][M] 20 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:06.015 MYMU22_FUT_CME [CV][M] 20 Sec #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:06.631 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-09-20 13:41:04.765388 | 2022-09-20 10:26:07.330 MYMU22_FUT_CME [CV][M] 20 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:07.334 MYMU22_FUT_CME [CV][M] 20 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:08.196 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43699 | 2022-09-20 10:26:09.000 MYMU22_FUT_CME [CV][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:09.004 MYMU22_FUT_CME [CV][M] Renko 8t #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:09.161 MNQU22_FUT_CME [CV][M] Renko 20t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-09-20 10:26:57.974 Saved Chartbook: NQ Renko.Cht. Time: 0.0219 seconds. | 2022-09-20 10:28:17.022 Saved Chartbook: Volume Divergence.Cht. Time: 0.0372 seconds. | 2022-09-20 10:28:17.062 Socket (2) | Error setting receive buffer size to 10485760. Unknown Windows error code 10055. | 2022-09-20 10:29:30.765 * Socket (2) | Error setting receive buffer size to 16777216. Unknown Windows error code 10055. | 2022-09-20 10:29:38.059 * Socket (2) | CloseSocket call. | 2022-09-20 10:30:54.221 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:30:54.222 Historical data download thread signaled to stop. | 2022-09-20 10:30:54.222 HD Request # 13 | Received 19504126 Intraday data records from 2022-08-18 14:11:55.231000 to 2022-09-16 09:29:57.257000 (28.8 days) and wrote 19504124 records for MNQU22-CME | 2022-09-20 10:30:54.223 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:57.257000 | 2022-09-20 10:30:54.226 HD Request # 13 | Completion time: 5m 35s. | 2022-09-20 10:30:54.226 HD Request # 13 | Intraday data download complete for MNQU22-CME. Unique request ID: 13 | 2022-09-20 10:30:54.226 Removing historical data download ID 13. | 2022-09-20 10:30:54.226 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:30:54.226 Triggering next historical data download in queue. | 2022-09-20 10:30:54.226 HD Request # 14 | Downloading Intraday chart data for MNQU22_FUT_CME to the file MNQU22_FUT_CME.scid. Service: cme | 2022-09-20 10:30:54.226 HD Request # 14 | Download start date-time: 2022-09-16 09:29:57.000000. File last date-time: 2022-09-16 09:29:57.257000 | 2022-09-20 10:30:54.229 HD Request # 14 | Using server: ds21.sierracharts.com port 10149 | 2022-09-20 10:30:54.229 Socket (4) | Creating socket. | 2022-09-20 10:30:54.229 Socket (4) | New receive buffer size: 5242880 | 2022-09-20 10:30:54.229 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-09-20 10:30:54.229 Socket (2) | Socket gracefully closed by remote side. | 2022-09-20 10:30:54.345 Socket (2) | Closed. | 2022-09-20 10:30:54.345 HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-09-20 10:30:54.488 HD Request # 14 | Sending historical data logon request message. | 2022-09-20 10:30:54.488 HD Request # 14 | Requesting Intraday data. Start date-time: 2022-09-16 09:29:57. Record interval: 0. Symbol: MNQU22 | 2022-09-20 10:30:55.108 HD Request # 14 | Decompressing data. | 2022-09-20 10:30:55.264 HD Request # 14 | Receiving Intraday data for MNQU22_FUT_CME starting at 2022-09-16 09:29:57.257000 | 2022-09-20 10:30:55.265 Socket (4) | CloseSocket call. | 2022-09-20 10:30:55.265 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:30:55.265 Historical data download thread signaled to stop. | 2022-09-20 10:30:55.265 HD Request # 14 | Received 1 Intraday data record from 2022-09-16 09:29:57.257000 to 2022-09-16 09:29:57.257000 (0.0 seconds) and wrote 0 records for MNQU22_FUT_CME | 2022-09-20 10:30:55.265 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:57.257000 | 2022-09-20 10:30:55.266 HD Request # 14 | Completion time: 1s. | 2022-09-20 10:30:55.266 HD Request # 14 | Intraday data download complete for MNQU22_FUT_CME. Unique request ID: 14 | 2022-09-20 10:30:55.266 Removing historical data download ID 14. | 2022-09-20 10:30:55.266 Real-time Intraday chart data file updates started for MNQU22_FUT_CME | 2022-09-20 10:30:55.266 Intraday chart data file opened for MNQU22_FUT_CME | 2022-09-20 10:30:55.266 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:30:55.266 Triggering next historical data download in queue. | 2022-09-20 10:30:55.266 HD Request # 15 | Downloading Intraday chart data for MYMU22_FUT_CME to the file MYMU22_FUT_CME.scid. Service: cbot | 2022-09-20 10:30:55.266 HD Request # 15 | Download start date-time: 2022-09-16 09:28:45.000000. File last date-time: 2022-09-16 09:28:45.113000 | 2022-09-20 10:30:55.268 HD Request # 15 | Using server: ds23.sierracharts.com port 10150 | 2022-09-20 10:30:55.268 Socket (2) | Creating socket. | 2022-09-20 10:30:55.268 Socket (2) | New receive buffer size: 5242880 | 2022-09-20 10:30:55.268 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-09-20 10:30:55.268 Socket (4) | Socket gracefully closed by remote side. | 2022-09-20 10:30:55.416 Socket (4) | Closed. | 2022-09-20 10:30:55.416 HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-09-20 10:30:55.600 HD Request # 15 | Sending historical data logon request message. | 2022-09-20 10:30:55.600 HD Request # 15 | Requesting Intraday data. Start date-time: 2022-09-16 09:28:45. Record interval: 0. Symbol: MYMU22 | 2022-09-20 10:30:56.429 HD Request # 15 | Decompressing data. | 2022-09-20 10:30:56.553 HD Request # 15 | Receiving Intraday data for MYMU22_FUT_CME starting at 2022-09-16 09:28:45.113000 | 2022-09-20 10:30:56.553 Socket (2) | CloseSocket call. | 2022-09-20 10:30:56.553 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:30:56.553 Historical data download thread signaled to stop. | 2022-09-20 10:30:56.553 HD Request # 15 | Received 1 Intraday data record from 2022-09-16 09:28:45.113000 to 2022-09-16 09:28:45.113000 (0.0 seconds) and wrote 0 records for MYMU22_FUT_CME | 2022-09-20 10:30:56.554 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:28:45.113000 | 2022-09-20 10:30:56.554 HD Request # 15 | Completion time: 1s. | 2022-09-20 10:30:56.554 HD Request # 15 | Intraday data download complete for MYMU22_FUT_CME. Unique request ID: 15 | 2022-09-20 10:30:56.554 Removing historical data download ID 15. | 2022-09-20 10:30:56.554 Real-time Intraday chart data file updates started for MYMU22_FUT_CME | 2022-09-20 10:30:56.554 Intraday chart data file opened for MYMU22_FUT_CME | 2022-09-20 10:30:56.554 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:30:56.554 Triggering next historical data download in queue. | 2022-09-20 10:30:56.554 HD Request # 16 | Downloading Intraday chart data for MYMM22_FUT_CME to the file MYMM22_FUT_CME.scid. Service: cbot | 2022-09-20 10:30:56.555 HD Request # 16 | Download start date-time: 2022-06-17 09:29:52.000000. File last date-time: 2022-06-17 09:29:52.572000 | 2022-09-20 10:30:56.557 HD Request # 16 | Using server: ds21.sierracharts.com port 10149 | 2022-09-20 10:30:56.557 Socket (4) | Creating socket. | 2022-09-20 10:30:56.557 Socket (4) | New receive buffer size: 5242880 | 2022-09-20 10:30:56.557 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-09-20 10:30:56.557 Socket (2) | Socket gracefully closed by remote side. | 2022-09-20 10:30:56.675 Socket (2) | Closed. | 2022-09-20 10:30:56.675 HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-09-20 10:30:56.818 HD Request # 16 | Sending historical data logon request message. | 2022-09-20 10:30:56.818 HD Request # 16 | Requesting Intraday data. Start date-time: 2022-06-17 09:29:52. Record interval: 0. Symbol: MYMM22 | 2022-09-20 10:30:56.973 HD Request # 16 | Decompressing data. | 2022-09-20 10:30:57.109 HD Request # 16 | Receiving Intraday data for MYMM22_FUT_CME starting at 2022-06-17 09:29:52.572000 | 2022-09-20 10:30:57.109 Socket (4) | CloseSocket call. | 2022-09-20 10:30:57.109 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-20 10:30:57.109 Historical data download thread signaled to stop. | 2022-09-20 10:30:57.109 HD Request # 16 | Received 1 Intraday data record from 2022-06-17 09:29:52.572000 to 2022-06-17 09:29:52.572000 (0.0 seconds) and wrote 0 records for MYMM22_FUT_CME | 2022-09-20 10:30:57.109 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:52.572000 | 2022-09-20 10:30:57.110 HD Request # 16 | Completion time: 1s. | 2022-09-20 10:30:57.110 HD Request # 16 | Intraday data download complete for MYMM22_FUT_CME. Unique request ID: 16 | 2022-09-20 10:30:57.110 Removing historical data download ID 16. | 2022-09-20 10:30:57.110 Real-time Intraday chart data file updates started for MYMM22_FUT_CME | 2022-09-20 10:30:57.110 Intraday chart data file opened for MYMM22_FUT_CME | 2022-09-20 10:30:57.110 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-09-20 10:30:57.110 Triggering next historical data download in queue. | 2022-09-20 10:30:57.110 No download requests in the queue to start downloads for. | 2022-09-20 10:30:57.110 Socket (4) | Socket gracefully closed by remote side. | 2022-09-20 10:30:57.244 Socket (4) | Closed. | 2022-09-20 10:30:57.245 |
| [2022-09-20 14:52:15] |
| Sierra_Chart Engineering - Posts: 24887 |
You need to go to the December 2022 contract for stock index futures. Refer to: Futures Chart Not Updating or Not Updating Frequently Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-20 21:02:38
| [2022-09-20 14:59:14] |
| User149333 - Posts: 23 |
That got it thanks :)
