Date/Time: Tue, 18 Mar 2025 11:21:55 +0000
opening next instances without opening prior instance
View Count: 914
[2022-09-20 10:03:27] |
User156295 - Posts: 104 |
Hi, is there any way to open let's say 4th instance without opening 2-nd and 3-rd?
[2022-09-20 15:45:32] |
John - SC Support - Posts: 38735 |
The only way to do this is to specify a sub-instance to start when you start the main instance. Refer to the following setting: General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 18:26:24] |
Yes, just while having opened the main would like to open any instance number without closing the main. Would you pls take this into consideration, such behaviour is very natural. |
[2022-09-20 20:35:28] |
We have set this as a Feature Request.
[2022-09-20 23:30:05] |
User90125 - Posts: 715 |
+1
[2022-09-21 07:47:31] |
Sierra_Chart Engineering - Posts: 18817 |
This is not something that we would add. After the instance is initially created you can manually start that instance any time from its installation folder, which is located in the main Sierra Chart folder.
[2022-09-21 12:22:39] |
It is fine and it is working, thank you : ))
