Date/Time: Tue, 18 Mar 2025 07:29:44 +0000
Is there a default setting in DOM for order execution quantity?
View Count: 589
[2022-09-19 20:45:18] |
User77918 - Posts: 3 |
I've got a chronic bad habit of forgetting to re-set the order quantity to 1 after exiting trades. I often scale into longs or shorts and exit all at once - often 5 or 6 MNQ lots. On my next trade, I find myself accidentally executing 5 or 6 MNQ contracts when I intend to execute 1 because I didn't re-set the DOM's execution quantity. Is your DOM strictly manual insofar as execution quantity? Or is there a DOM setting I can make to re-set the order quantity by default back to 1 after I exit my trades? Thanks!! |
[2022-09-20 14:50:03] |
John - SC Support - Posts: 38735 |
There is not a reset for the quantity. The system keeps the last quantity that was set until it is changed.
