Date/Time: Tue, 18 Mar 2025 02:32:15 +0000
not able to set volume profile
View Count: 810
[2022-09-19 17:31:14] |
MOHAMMAD TAMIR - Posts: 9 |
hey, i'm new here and please guide me to setup the volume profile properly |
[2022-09-20 10:59:08] |
Sierra_Chart Engineering - Posts: 18812 |
Go through the step-by-step instructions here: Volume By Price Study: Step By Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 17:20:15] |
Hey there, Thanks for volume profile guide the other problem I'm facing is that I can't find a VWAP whose bands work like moving averages what I mean by that is if the price moves up then VWAP bands starts crossing each other i have that in ninjatrader platform but, i can't find it here so please help. |
[2022-09-20 18:07:52] |
John - SC Support - Posts: 38735 |
The only way for VWAP bands to cross each other is to have multiple VWAPs that start at different times. Refer to the information for the VWAP study here: Volume Weighted Average Price (VWAP) with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
