Date/Time: Tue, 18 Mar 2025 07:39:41 +0000
c lea
View Count: 806
[2022-09-19 17:28:52] |
User290457 - Posts: 1 |
cant install or download sierra
[2022-09-20 10:59:54] |
Sierra_Chart Engineering - Posts: 18816 |
We recommend in this case to use the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
