Date/Time: Tue, 18 Mar 2025 02:41:42 +0000
Datos
View Count: 796
[2022-09-19 17:26:08] |
Jose Baptista - Posts: 12 |
buen dia, no tengo acceso a los datos...voy a FILE NO PUEDO CONNECT DATA FEED. NECESITO QUE AYUDEN EN ESTE TEMA GRACIAS |
[2022-09-19 23:35:28] |
Sierra_Chart Engineering - Posts: 18812 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
