Date/Time: Tue, 18 Mar 2025 06:17:13 +0000
Mornigstar Data
View Count: 404
[2022-09-19 17:25:18] |
CCTT - Posts: 6 |
Hi Sierrachart support, EURUSD_BIDASK I get at the moment from NY (FXCM data) via SC server ds12 with 109ms ping from my location. (Germany) I am interested in the Morningstar data. ^EURUSD_BIDASK Only I can't find any information how to get them. And from where the data comes from for ping time. $21 additional and what else is needed ? With kind regards |
[2022-09-19 22:28:18] |
Sierra_Chart Engineering - Posts: 18812 |
We really do not not think there is any advantage at all by using MorningStar for EURUSD.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-19 22:28:27
