Date/Time: Tue, 18 Mar 2025 12:37:10 +0000
MES orders on ES chart
View Count: 979
[2022-09-19 16:34:54] |
rondawes - Posts: 39 |
Is it possible to configure so that MES orders to show on an ES chart?
[2022-09-20 11:11:19] |
Sierra_Chart Engineering - Posts: 18817 |
Yes. Refer to this Chart Setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
