Date/Time: Mon, 17 Mar 2025 18:17:48 +0000
New bars appear after copying a chart from another chartbook
View Count: 818
[2022-09-19 01:10:27] |
User380359 - Posts: 8 |
I duplicated a chart from Chartbook B to Chartbook A, now the chart is showing bars that didn't exist before and I don't know how to make them disappear, please help. The chart is point and figure 1-8. |
[2022-09-19 11:41:41] |
Sierra_Chart Engineering - Posts: 18809 |
Go into Analysis >> Studies and remove whatever study is drawing those bars: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-19 12:55:34] |
They disappeared the next day without me doing anything, issue solved I guess.
Date Time Of Last Edit: 2022-09-19 12:56:30
