Date/Time: Tue, 29 Sep 2026 18:37:21 +0000
ARM 64-bit processor version of Sierra Chart
View Count: 2594
| [2022-09-18 07:56:10] |
| user8888 - Posts: 159 |
GM If I'm not mistaken I could run the "ARM 64-bit processor version of Sierra Chart" in the M1, right? If that's affirmative, I would love to give it a try. How could I? Thank you! |
| [2022-09-18 08:55:11] |
| binaryduke - Posts: 387 |
Theoretically by running Windows in Parallels. Then it would be running natively rather than using the Windows x64 emulation. You will not be able to run this directly on MacOS.
| [2022-09-18 09:53:21] |
I see. What a pity. ok, thanks @binaryduke
| [2022-09-20 09:59:45] |
| Sierra_Chart Engineering - Posts: 25001 |
Refer to this thread for the ARM 64 files: Sierra Chart Executables for ARM 64 Processor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
