Date/Time: Fri, 07 Feb 2025 15:01:10 +0000
how can I draw a line on the chart using spreadsheet or color bar based on alert condition
View Count: 1107
[2022-09-17 00:31:32]
User396 - Posts: 55
I would like to draw a line (basically sequence of either green or red square for each candle of the main chart) based on some alert condition. Alert condition is working with other option.
But I would like to draw a straight line with red or green square based on this condition. It doesn't matter if it is on Chart region #1 or any other number.
Is this possible using spreadsheet study or color bar based on alert condition?
Can I draw multiple lines of squares based on alert condition?
Thank you,
b
Date Time Of Last Edit: 2022-09-17 02:36:13
[2022-09-17 10:25:38]
Sierra_Chart Engineering - Posts: 18330
Yes we do recommend using the Color Bar Based on Alert Condition:
This can also be used to draw other types of Draw Styles:
Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars
You can add multiple instances of this study to the chart to draw multiple Lines or other types of Draw Styles.
Date Time Of Last Edit: 2022-09-19 16:39:40
