Date/Time: Mon, 17 Mar 2025 18:22:47 +0000
Market Depth Historical Graph/Secondary Numbers
View Count: 402
[2022-09-16 16:45:25]
User117347 - Posts: 46
Sierra,
In the Market Depth Historical Graph study, can the secondary numbers/coloring be set to paint when a "volume percentage increase" occurs instead of a fixed secondary number?
In other words, I'd like to have the secondary numbers paint only when a preselected "percentage increase" occurs in the volume. So, for example, if the secondary number is set to print only when the next number is "20% higher", and the previous number is 100, if the next volume number is 120 then the secondary number would print in its selected color.
This way I can clearly see when volume on the bid or offer is dramatically increasing by percentage. I hope this is clear.
Thanks,
Jim
[2022-09-16 17:31:03]
Sierra_Chart Engineering - Posts: 18809
No this is not supported. And there are no plans for this.
