Date/Time: Sat, 19 Sep 2026 21:23:47 +0000
Trade Windows - Types of orders list reduced?
View Count: 781
[2022-09-16 14:26:27]
User58008 - Posts: 32
I would like to know if there is a possibility to choose my own / reduce the list of the order types that is shown in the Trade Window in the bottom part of the Main tab under the "Use Attached Orders"... now, when I open roll up the menu with the order types there is app. 50 of order types although I use just 3... and it is very clumsy to have them there when not used.
I enclose a print screen with the menu. THank you
imageSnĂ­mek obrazovky 2022-09-16 162550.jpg / V - Attached On 2022-09-16 14:26:09 UTC - Size: 62.66 KB - 191 views
[2022-09-16 15:06:34]
Sierra_Chart Engineering - Posts: 24892
That particular list cannot be reduced. We will have to see about that capability.
