Date/Time: Mon, 14 Sep 2026 11:03:15 +0000
CHARTBOOK TAB COLOR
View Count: 1548
| [2022-09-16 05:20:27] |
| User41636 - Posts: 35 |
As I switch among my Chartbooks, it would be helpful in telling the tabs apart easily if varying background colors could be assigned to the individual tabs – as opposed to setting the same background color for all the “not selected (not active) Chartbooks” taken together. I even tried the “CHARTBOOK TAB CONTROL BACKGROUND COLOR” option under GLOBAL SETTINGS|GRAPHIC SETTINGS, despite not finding that one listed in your comprehensive descriptive commentary. Any solution?
| [2022-09-22 03:23:14] |
As I switch among my Chartbooks, it would be helpful in telling the tabs apart more easily if different background colors could be assigned to the individual tabs – as opposed to setting the same background color for all the “not selected (not active) Chartbooks” taken together. I even tried the “CHARTBOOK TAB CONTROL BACKGROUND COLOR” option under GLOBAL SETTINGS|GRAPHIC SETTINGS, but that option does not seem to listed anywhere in your explanations and definitions of terms. Any thoughts?
| [2022-09-22 14:22:26] |
| John - SC Support - Posts: 47854 |
There are only the options for the Selected Chartbook tab and the other Chartbook tabs.
