Date/Time: Wed, 19 Mar 2025 18:49:12 +0000
Multiple bots trading
View Count: 945
[2022-09-16 03:06:13] |
User857150 - Posts: 11 |
We know that you advise against running multiple bots on the same symbol & the same account. We’ve solved it on our side, or alternatively, we can use one separate account for each bot. Considering each instance of Sierra Chart is very lightweight and runs on its own thread, what’s your vision about running numerous bots at the same time? An instance for each bot? A group of bots on each instance? The concerns are: overall system durability & robustness, performance, and efficiency. |
[2022-10-01 13:13:42] |
User61576 - Posts: 445 |
SC support?
[2022-10-04 15:31:03] |
Sierra_Chart Engineering - Posts: 18843 |
You can certainly run multiple automated trading systems in a single instance of Sierra Chart. That is definitely not a problem. There will be complete stability within Sierra Chart. No issue with that. And performance is something that you have to analyze. It is not something we can advise about. As long as you have worked out conflicts with trading the same symbol and account with multiple automated trading systems, that is the main issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
