Date/Time: Mon, 21 Apr 2025 04:35:50 +0000
multiple data feeds?
View Count: 1429
[2022-09-16 00:57:45] |
User244219 - Posts: 4 |
hi i am wondering is it possible to trade multiple data feeds? for instance i use the iq feed to trade the ftse 100 futures but want to use the denali data feed to trade oil and gold futures?
[2022-11-21 21:15:39] |
$tack - Posts: 100 |
I had a similar question. I have a iqfeed subscription and would like to use the data for certain products, and denali for others. Is this possible? Thanks |
[2022-11-21 21:33:28] |
Using Multiple Data and Trading Services at the Same Time after reading the documentation at the link above, do I understand correctly that to achieve mutiple connections to different data feeds requires multiple instances of SC each connected to separate data feeds? |
[2022-11-22 16:15:34] |
John - SC Support - Posts: 39362 |
Sierra Chart is setup to allow data from the defined Current Selected Service as well as from our Data Feeds. First, the system will check to see if you are setup to get real-time data for the particular instrument from our data services, if so, then it gets the data from us. Next, if your account is not setup for real-time data for a particular instrument, then it will look to get that data from the connection you have setup in the Data/Trade Service Settings for the Current Selected Service. If it can get the data from there, then it does. Next, if the system can not get the data from either of the above, then you will get an error message stating that it could not get the data from your selected service provider. -- Therefore, if you are setup to get data from IQ Feed and from Sierra Chart, then you will get the data from us first and any other data from IQ Feed. This will occur within a single instance of Sierra Chart. You do not need multiple instances in this case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-25 22:18:59] |
Sierra_Chart Engineering - Posts: 19285 |
In the case of IQ Feed you must have two separate installations to do this: I had a similar question. I have a iqfeed subscription and would like to use the data for certain products, and denali for others. Is this possible?
Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-26 16:32:26
[2023-01-24 20:02:29] |
Ok I think the last two responses from Sierra are saying different things. But since I don't see a way to run IQFeed and Denali at the same time then in the same instance then, I assume Engineering's response is right and not SC Support's response. In order to see the consolidated tape for all US Equities, and the Nasdaq depth (from Nasdaq totalview in Denali feed) at the same time in the same instance, I need to subscribe to U.S. Equities (NYSE, NASDAQ, AMEX) in the SC Realtime Feed in addition to Nasdaq totalview in Denali? Thanks |
[2023-01-24 22:16:39] |
The responses are not saying different things. Engineering response was directly to the point for the particular question posted. What exactly do you want to do in terms of getting data from IQFeed and Denali? In order to see the consolidated tape for all US Equities, and the Nasdaq depth (from Nasdaq totalview in Denali feed) at the same time in the same instance, I need to subscribe to U.S. Equities (NYSE, NASDAQ, AMEX) in the SC Realtime Feed in addition to Nasdaq totalview in Denali?
You can do this by subscribing to both the Sierra Chart Exchange Data Feed with the U.S. Equities and the Denali Exchange Data Feed with the NASDAQ TotalView. When you open a chart, the symbol you use determines which data feed the information comes from. The data for a standard symbol (such as IBM) will come from the Sierra Chart Exchange Data Feed, whereas the data for a symbol with the -NQTV suffix (such as IBM-NQTV) will come from the Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-25 20:00:03] |
So I can use both symbols on the same chart so that I can have depth and regular data on there? What exactly do you want to do in terms of getting data from IQFeed and Denali?
I am trying to use the IQFeed data that I'm already paying for (and using with other programs), for US Equities, and use your Denali Nasdaq Totalview along with it. Essentially what I think you're saying I can do with the SC Exchange Data + Denali Feed. But I think you're saying I can't do it with IQ Feed + Denali. |
[2023-01-26 23:41:43] |
You need to have separate charts: So I can use both symbols on the same chart so that I can have depth and regular data on there?
It is planned as an upcoming feature, for us to combine this data, but that could still be 2 to 3 months away. To avoid issues and conflicts you really need a separate installation of Sierra Chart as compared to IQ Feed, to use either the Sierra Chart Exchange Data Feed or the Denali Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-26 23:41:59
[2023-02-02 19:13:12] |
Is the feature you're talking about the same as what you refer to here: The consolidated tape data feed for US equities will be offered through the Denali Exchange Data Feed sometime before the end of the year 2022.
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notesthanks |
[2023-02-02 22:50:50] |
Yes, the NASDAQ TotalView exchange is the one that does not have the consolidated tape yet, therefore we are adding to it.
