Date/Time: Tue, 26 Nov 2024 14:49:13 +0000
Hot-key issue
View Count: 1046
[2014-05-16 14:46:04]
User87197 - Posts: 65
Hiya. The "Next Chartbook" and "Previous Chartbook" hotkey bindings often have an issue where they work for one press, but subsequent presses no longer move to the next chartbook when you have a 'detached' chart window selected. I think it might be that changing the chartbook leaves you without an active chart-window selected so the keystroke isn't being recognised by SC. Is there a way to remedy this? Like perhaps linking these commands to selecting the main SC window so further presses are still recognised? Any help would be much appreciated as manually reselecting windows all day to use this function is very cumbersome.
Many thanks :)
[2014-05-20 06:53:50]
We will check on this.
[2014-05-20 06:59:37]
This should be fixed in the next release. Let us know.
