Date/Time: Mon, 17 Mar 2025 18:22:49 +0000
[User Discussion] - feature request: window-layout settings
View Count: 914
[2022-09-15 14:19:17] |
User197957 - Posts: 2 |
Hi, I am super satisfied with Sierra Chart. But one missing feature would make my life a lot easier: I used my laptop at least three different monitor constellations, single-screen, dual-screen, wide-screen. It would be very helpful when you could load/save different window layout within one chartbook. I know that I save the window position per chartbook. But it is not at all practical to manually sync all other settings between chartbooks. I would be very happy if this feature would be considered soon. Thank you very much. |
[2022-09-15 14:29:06] |
JohnR - User831573 - Posts: 320 |
As a possible work around, you could use AutoHotKey and create a macro for each layout you want that would select / make active each chart window and then move & size it to where you want. I am not a pro at AHK, but do use it to supplement what SC has to offer. AS you do this, keep in mind you can create / edit the title bar on each chart, to be easy to identify. The forums for AHK are very helpful and quick to assist. Hope this helps, JohnR |
[2022-09-16 09:50:57] |
Thank you very much. Very good tip - problem bypassed. Regards, ChristophH |
