Date/Time: Mon, 17 Mar 2025 18:17:48 +0000
MBO on Main and 2nd Instance
View Count: 887
[2022-09-15 13:32:19]
dvant krypto - Posts: 43
I have the MBO loading on a DOM in both instances. They load ok, but on the 2nd instance, no matter what I do, I cannot restrict the minimum to what I want - the settings are the same as the Main Instance. Should I delete one of the DOMs? - if so, I'd rather it be the one in the Main Instance.
Thanks.
[2022-09-15 13:55:50]
Sierra_Chart Engineering - Posts: 18809
Yes this is true and cannot be changed.
[2022-09-15 14:01:10]
Ok. So, is this because I'm using MBO data in two locations or because this is how MBO data is in sub-instances?
[2022-09-15 15:21:56]
It has to do with accessing the market by order data in the sub instance which gets the data from the main instance.
