Date/Time: Thu, 24 Sep 2026 09:19:16 +0000
Inconsistent fonts in newer version
View Count: 677
[2022-09-15 03:40:37]
User900285 - Posts: 101
There was an issue in the prior version 2437 and now in 2438 it still appears there.
It is an issue with a certain font. I have not found an exact way to replicate it and I noticed that sometimes it was not occurring.
This is the issue.
In Graphics Settings - Global > Fonts, I set the Settings Windows Font to Open Sans Semibold with a font size of 11.
Normally when you first change the font it will display properly. The issue has been when closing and re opening Sierra Chart, maybe after a system restart.
Certain areas of the settings window display an incorrect font which is certainly not Open Sans Semibold.
Try to use the exact font and size that I have specified and you might be able to replicate it.
This incorrect font only appears on the bottom buttons of the settings window and on other windows that share the settings window font. One of them is the remote study compiler.
[2022-09-15 04:25:53]
Sierra_Chart Engineering - Posts: 24949
We will look into this.
[2022-09-15 19:01:07]
This is fixed in version 2439.
