Date/Time: Tue, 18 Mar 2025 08:52:15 +0000
Display a bars every second
View Count: 436
[2022-09-15 02:59:54] |
User462152 - Posts: 12 |
Bars are not updated during periods when no trades are made. Is it possible to always update this? For example, if the chart update is set to 1 second, the bar will always be updated every 1 second. "Include Columns With No Data" in the "Chart Settings" options allows me to show non-traded bars, but still the bars are not shown until a trade is made. |
[2022-09-15 03:21:23] |
Sierra_Chart Engineering - Posts: 18817 |
No, this definitely cannot change at all. No possibility.
[2022-09-15 03:29:36] |
OK. Thank you for your quick response. |
[2022-09-15 14:09:14] |
JohnR - User831573 - Posts: 320 |
Here is a wild guess, support can tell you if it would work? Create a study, that is sc.AutoLoop = 0; Manual looping. Create a timer and whenever your timer expires, plot a value, anything and make it hidden. I am guessing this will force SC to create a bar every 1 sec or whatever you are looking for. Hope this helps, JohnR |
