Date/Time: Mon, 17 Mar 2025 18:28:10 +0000
BMF exchange
View Count: 916
[2022-09-14 16:47:53] |
User733502 - Posts: 46 |
Hi SC, My BMF symbols IND WIN DOL WDO are delayed. It seems by a full day. What do I need to do to have 10 min delayed or live data for BMF exchange. Thank you. JS |
[2022-09-15 09:25:48] |
Sierra_Chart Engineering - Posts: 18809 |
Sierra Chart does not offer this data delayed or real time. You can get this data probably through IQ Feed, CQG or possibly Interactive Brokers. These are all supported: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-15 13:56:40
[2022-09-15 13:26:00] |
The BMF exchange is in the CHART SETTINGS and I'm able to load the symbol and view historical and intra day charts. The issue is that I need to do a DELETE\DOWNLOAD DATA to refresh and it seems the data is updated at the end of the session.
[2022-09-15 13:56:13] |
Yes that makes sense. Sierra Chart does not provide this data delayed or real time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-15 13:56:50
