Date/Time: Mon, 17 Mar 2025 18:25:48 +0000
add an account
View Count: 351
[2022-09-14 16:47:19] |
User417336 - Posts: 5 |
can i add another account to sierra chart and if so how? I want to start proptrading for nextproptrader. where can i add the account or do i just have to add it in the sierra chart software? best regards |
[2022-09-14 23:15:58] |
John - SC Support - Posts: 38711 |
You probably do not need another Sierra Chart account. With the account you have, you can have as multiple installations of Sierra Chart on the same computer. Therefore, if you have a primary trading account and you want to start prop trading, then our recommendation is to install a second Sierra Chart on the same computer. You will log into both with the same information, but you will have one setup to connect to your primary trading service, and the other for the prop firm. Refer to the following information for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart You can do this on two different computers, and for right now you would be fine, but if you ever want to use the Denali Exchange Data Feed, then by having the installations on one computer you can get the data to both installations at no extra cost. With a second computer you would have to pay 2 exchange fees. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
