Date/Time: Mon, 17 Mar 2025 18:28:09 +0000
Additional System (second laptop)
View Count: 347
[2022-09-14 16:46:52] |
User653356 - Posts: 1 |
have paid and activated for the additional system (4 computers, $12/month) but my second laptop is not working or receiving live data. how can i connect it or make it recieve data please? thanks |
[2022-09-14 23:12:14] |
John - SC Support - Posts: 38711 |
The particular setting you changed is for the Sierra Chart software to run on 4 computers at the same time. By default, you are allowed up to 3 computers at the same time running the Sierra Chart software, so you may not need this option at all if you do not have 4 computers. This is separate from the exchanges. For the Denali Exchange Data Feed, the exchange rules are that you can have 2 instances on a single computer, but if you want data to two different computers at the same time, you need to pay the Exchange Fee twice. Refer to the information/instructions at the following link: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
