Date/Time: Fri, 26 Apr 2024 20:07:39 +0000
Volume by Price question
View Count: 1809
[2013-04-29 17:04:19] |
User22396 - Posts: 191 |
is there a way to plot the 'Peaks & Valleys' prices on the price scale? |
[2013-04-29 17:14:16] |
Yes. Refer to the Peaks and Valleys related Input Settings for the Volume by Price study: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-29 17:14:58] |
Just realized your referring to the Price scale, then no there is no way to display line labels.
[2013-04-29 17:20:58] |
yes meant line labels on price scale... can this be added in future release? whether on price scale or even somewhere on the line itself? thanks |
[2013-04-29 17:28:10] |
We will be looking to add this capability later on. Not now.
