Date/Time: Mon, 17 Mar 2025 18:28:09 +0000
SpreadSheet Automated Trading
View Count: 895
[2022-09-13 19:15:35]
User964846 - Posts: 38
Hey Sierra.
I would like to use Spreadsheets, so that I will have an order waiting at a specific MA Band.
Unfortunately, the Level I would like the order to be ready and waiting at, is Always Changing. The chart is a 15 second chart, so each new bar can change the level the order should be sitting at. Although I do not know if SS can keep up with cancellations and new entries on that time frame.
Is it possible for Sierra to Place an Order and Cancel an existing order, every 15 seconds, when using Spreadsheets for Order Entry and Cancellation?
[2022-09-14 00:08:33]
John - SC Support - Posts: 38711
This should not be a problem, but try it in Simulation mode and see how it works for you.
[2022-09-14 17:41:18]
So, I've been attempting to do this with simulation mode. & I have found that nothing works, no matter what I do. I guess, maybe I'm doing something wrong -- I set the formulas to be super easy -- So, My issue is NOT coding, but with how I'm implementing Spreadsheets.
So my original Question still remains: Can I cancel orders immediately using Spreadsheets? Right now I am following Sierra's advice, and using Cell J27. Should I be doing something different?
Have you ever seen Spreadsheets cancel a working order On EVERY new bar? I am asking, because what I am trying to do, Might not be possible.
Date Time Of Last Edit: 2022-09-14 17:43:46
