Date/Time: Tue, 26 Nov 2024 13:48:10 +0000
Does SC keep a trade log?
View Count: 1020
[2014-05-16 00:54:51]
Demi1201 - Posts: 68
Hello everybody,
Thanks for all the help you have given me so far.
Here's my problem today:
I installed SC on a new computer and migrated my settings by copying the contents of the appropriate directory (on SC support's suggestion)to the corresponding directory in my current SC installation.
So I had my settings, but then whenever I open trades (in Advisor mode and with "use order fill calculated position" checked) SC attributes my long or short position to a position entered previously, usually quite far from the money.
I think the settings and files I copied into the SC directory contained logs of previous trades that SC is adding to whenever I open a trade.
I wonder if you could suggest a simple fix for this, like the name of a file that needs to be erased to dispense with all this. Is that possible?
Thanks,
Demi
[2014-05-16 01:45:26]
Could it be tradepositiondata.xml?
Can I delete it and trust SC will generate a new file?
[2014-05-16 01:58:03]
The file is TradeActivityLog.DAT. You need to exit from Sierra Chart. Delete this file in the main Sierra Chart folder and then start Sierra Chart.
[2014-05-16 08:32:57]
Thank you. That worked for older orders.
However, when I deleted the TradeActivityLog.dat I was in a position. (My mistake.)When I later exited that short position SC logged in a new long trade and now sees me long when I'm really flat.
OK, I deleted several times the file in question but the trade is retained by the program. Probably a daily log somewhere. Will it disappear tomorrow? I can live with this distortion for a day or two.
Thanks.
[2014-05-16 08:58:02]
This is most likely because order fills are being downloaded from your IB account.
You can disable this with Global Settings >> Data/Trade Service Settings >> More Interactive Brokers Settings >> Download Historical Order Fills on Connect.
Date Time Of Last Edit: 2014-05-16 08:58:27
