Date/Time: Mon, 17 Mar 2025 18:17:47 +0000
chartbook compatibility
View Count: 868
[2022-09-13 17:43:26]
User44586 - Posts: 1
I have a problem with these chartbooks. When I try to upload it to the platform I get the following message; The chartbook file is not compatible, Contact Sierra Chart for support for help with converting it.
The file is attached. Thank you.
Private File
Private File
Private File
[2022-09-13 23:58:01]
John - SC Support - Posts: 38711
Attached are your updated chartbooks.
attachmentChartbook1.Cht - Attached On 2022-09-13 23:57:43 UTC - Size: 12.03 KB - 118 views
attachmentNQ_Wem_2018.cht - Attached On 2022-09-13 23:57:50 UTC - Size: 83.88 KB - 136 views
attachmenttest_Wem_2020.cht - Attached On 2022-09-13 23:57:56 UTC - Size: 83.78 KB - 126 views
