Date/Time: Mon, 17 Mar 2025 18:17:49 +0000
Usage time expires
View Count: 431
[2022-09-13 17:41:52] |
User134858 - Posts: 1 |
Hi Team, My usage time on my SC account is about to expire. Please help me in what service package I need to go for in case I want the following till end of 2022. - only simulation account to be used - delayed data to CME i.e. micro e-mini S&P 500 and micro e-mini Nasdaq 100 I will switch to live account and real time data only in Jan 2023. Thanks & Regards, |
[2022-09-13 23:51:55] |
John - SC Support - Posts: 38711 |
Your Simulation accounts are available with any package, so there is no issue with this. Since you are only needing the Delayed Data, you can be on one of the Base packages (packages 3 and 5), depending on what you need in terms of the features between the Standard and the Advanced options. Refer to the information here: Description of Service Packages and Pricing: Base Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
