Date/Time: Mon, 17 Mar 2025 18:17:46 +0000
only 10 levels for RB
View Count: 398
[2022-09-13 17:20:33]
voided - Posts: 45
I'm using the denali feed with MBO. I have checked the market depth settings and global symbol settings (both have maximum market depth levels at 0), but RB on NYMEX is still only showing 10 levels of depth. Can you check to see if there is some problem?
[2022-09-14 11:11:05]
Sierra_Chart Engineering - Posts: 18809
We needed to add market by order support for the symbol. This is done, but will not go into effect immediately.
