Date/Time: Mon, 17 Mar 2025 18:22:47 +0000
Trade service setting missing for GAIN data feed on Version 2425 or higher
View Count: 468
[2022-09-13 17:18:36] |
ADRTvent - Posts: 23 |
The Trade "service settings" fields are missing for GAIN data feed on Version 2425 or higher. When going to SrvSet>main Settings the fields for "service settings" are missing when the selected service is GAIN Capital/OEC [data], when selected there are no fields to enter the server, username, password, account# etc.., all those are missing and I cannot use the service at any version higher than 2425. Also the option to select GAIN Capital/OEC [TRADING] is also missing from the list, what appears is the [data] option as the only option for GAIN, I am subscribed under advanced at $36 per month so not sure what happened please advise
[2022-09-13 23:25:34] |
John - SC Support - Posts: 38711 |
With version 2417 we removed support for Gain Capital. Refer to the information here; https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2417 If you want to downgrade to a version prior to 2417, then follow these instructions: Software Download: Full Control Rollback Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-14 18:25:21] |
Thank you for the quick reply , will I be able to use this version of SC (2417) indefinately? or will eventually a forced update be required at some point? Does the replacement (TETON) still work with Gain trading accounts? (so I can use the TETON for data but my trades will still route to my gain accounts?) please advise |
[2022-09-14 19:09:15] |
Sierra_Chart Engineering - Posts: 18809 |
will I be able to use this version of SC (2417) indefinately? Yes for now but there are no guarantees longer term. There could be changes on the side of Gain capital or the Sierra Chart side preventing you from using that version.Does the replacement (TETON) still work with Gain trading accounts? (so I can use the TETON for data but my trades will still route to my gain accounts?) please advise
No, you have to use a different broker supporting Teton order routing.One change that will occur, no later than November is that you will need to move to Service Package 11 to use Gain capital no matter what version you are running. Description of packages: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-14 19:12:38
[2022-09-14 23:05:33] |
Infinite - Posts: 134 |
Thank you for the quick reply , will I be able to use this version of SC (2417) indefinately? or will eventually a forced update be required at some point? Does the replacement (TETON) still work with Gain trading accounts? (so I can use the TETON for data but my trades will still route to my gain accounts?) please advise Denali/Teton far out preforms anything Gain has ever had. Go 100% with Denali/Teton it is hands down superior! Date Time Of Last Edit: 2022-09-14 23:06:21
