Date/Time: Mon, 17 Mar 2025 18:22:48 +0000
Continuous Futures Contract - Back Adjusted
View Count: 921
[2022-09-13 13:33:48] |
MarkusK - Posts: 104 |
Hi, I have a quick question regarding the "Continuous Futures Contract" option: I wonder if I should use the "Volume Based Rollover" or the "Volume Based Rollover, Back Adjusted" option. (My question is only about the "Back Adjusted" - it's clear for me that I generally want the Volume Based Rollover) I read the documentation and understood what "Back Adjusted" does, but I still don't understand the real benefit of using this option. Any insights/advice from more experienced traders on why one should use (or not use) the "Back Adjusted" option would be very appeciated. |
[2022-09-13 13:41:00] |
Sierra_Chart Engineering - Posts: 18809 |
We do not recommend using the Back Adjusted option.
[2022-09-13 14:39:30] |
That's good to know, thanks a lot for the quick reply and your recommendation!
