Date/Time: Mon, 17 Mar 2025 18:17:46 +0000
Session time in Chart Header
View Count: 385
[2022-09-13 09:55:58]
User361939 - Posts: 167
How can i add session Time of chart into header?
I use charts with different session time (with over night options on) but i expierienced from time to time that this time is reseting so the chart might look different. If i add session time to Chart Header i will automatically know if time set is correct.
Best Regards
[2022-09-13 11:49:21]
Sierra_Chart Engineering - Posts: 18809
This is not supported. Only the time zone can be added.
Regarding the changing of the session times, refer to:
Chart Session Times: Session Times Automatically Changing Unexpectedly
