Date/Time: Mon, 17 Mar 2025 18:22:48 +0000
Replay not working again
View Count: 460
[2022-09-13 02:19:40]
User897692 - Posts: 9
Yesterday I was replaying a session from June 10 2022 and everything was working fine. Today I'm trying to replay a session from June 13 2022 on the 1 minute chart and the bars are loading 1 minute at a time, not in real time. The VbP on this chart is also not loading. Also the separate delta window is not loading data correctly.
Date Time Of Last Edit: 2022-09-13 02:20:07
imageReplay 1.00X ESU22-CME [CV][M] 1 Min #1 2022-09-12 19_16.png / V - Attached On 2022-09-13 02:17:00 UTC - Size: 35.74 KB - 88 views
imageReplay 1.00X ESU22-CME [CV][M] 1 Min #7 2022-09-12 19_16.png / V - Attached On 2022-09-13 02:17:24 UTC - Size: 11.04 KB - 92 views
[2022-09-13 09:29:00]
Sierra_Chart Engineering - Posts: 18809
It sounds as though some of the data is 1 Minute data.
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
Fully re-download the data for all contract months following the instructions here:
[2022-09-13 22:19:25]
It was set to tick by tick. But re-downloading data seemed to do the trick.
Thank you!
