Date/Time: Mon, 17 Mar 2025 18:22:48 +0000
rollover
View Count: 833
[2022-09-12 14:49:25] |
User663128 - Posts: 3 |
Despite being checked for auto rollover, my index contracts are still showing Sept.
[2022-09-12 18:52:30] |
Sierra_Chart Engineering - Posts: 18809 |
CME stock index futures will not roll over automatically today. And you need to understand the option that you are using and exactly what it does and when: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
