Date/Time: Mon, 17 Mar 2025 18:28:08 +0000
Zig Zag Mode 2 Calculation
View Count: 654
[2022-09-12 13:34:23]
User135370 - Posts: 162
Hi
In Mode 2 of the Zig Zag indicator
1. If the Reversal Amount for Calculation Mode 2,3 Input value has been exceeded
If I am trading the ES for example and a tick is 0.25 if I make the setting to 4 is that a price change of 4 ticks or 4 points
If I wanted a price change of 4 tick, do I enter 4 or 1 noting that a tick is 0.25
I am going of the 4 means 4 price changes please confirm I couldn't find it in the documentation
[2022-09-12 15:44:15]
John - SC Support - Posts: 38711
The Reversal Amount for Calculation Modes 2 and 3 is the actual price change value (points)
Therefore, a setting of 4 would mean a price change of 4 (4106 to 4110).
[2022-09-12 18:45:43]
Thanks John
Just to clarify
0.04 is 4 price levels or 4 asking because the default is 0.01
[2022-09-12 19:21:15]
A value of 0.04 is a price movement of 0.04. It is an actual value, not ticks, or percentage, etc. When you make the value larger, like 4, you will then see fewer inflection points and the need for the line to move at least 4 points.
