Date/Time: Tue, 26 Nov 2024 13:26:48 +0000
Net Change Requests
View Count: 1316
[2014-05-15 16:45:01] |
sampater - Posts: 244 |
1) Could I ask for add a feature: "Display in the TickSize" for the Net Change, which is displayed both in the Chart Header and in the Tool Values Window? This way of displaying will be more readable if I use a strategy based on variability of price action in reference to TickSize. 2) In the Tool Values Window, the Net Chg is displayed green, when a LAST of current bar is equal a LAST of previous bar. Could you please implement that it is displayed gray or black like in the Chart Header? This case of equal the LAST of bars is quite often in the Futures. Thank you, Marek |
[2014-05-16 03:11:53] |
1. This is not likely to be added. 2. This will be solved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-16 08:27:15] |
Thank you Marek |
