Date/Time: Tue, 26 Nov 2024 13:20:14 +0000
Bar Close Above POC on the TPO VAL Study
View Count: 1273
[2014-05-15 16:37:39]
infpz - Posts: 826
Alert would be =C>SG2
[2014-05-15 18:15:03]
Yes. That will work but it will give a lot of signals because many bars will be above the point of control.
[2014-05-15 18:17:31]
infpz - Posts: 826
If we enable "enable on bar close only" would that be more suitable?
[2014-05-16 05:07:42]
Yes. But is this just used as a Simple Alert on the study itself or are you using the Color Bar Based on Alert Condition?
[2014-05-16 11:36:11]
infpz - Posts: 826
I put just a simple alert on the study itself but I could use whichever one would work best.
[2014-05-16 17:01:04]
This depends upon what is required. If you are just using a Simple Alert for current bar alerting, and not coloring the bars, then the formula is fine.
