Date/Time: Thu, 10 Sep 2026 09:01:33 +0000
Data Realtime - Access
View Count: 1235
[2022-09-10 16:19:27]
denarius - Posts: 16
I understand I have full access to CME realtime data.
I noticed when I go to Chart Settings & click on the symbol & then select to change the symbol I get the Find Symbol box with the available symbols listed by exchange. I see after CME & CBOT the phrase (Realtime) - I assume because I have subscribed for all CME controlled symbols. But i also see CFE with (Realtime) - see attached. Is that a part of the CME package that I have? If I select one of those symbols, will I get real time data?
Thank you.
imageReal Time Data.JPG / V - Attached On 2022-09-10 16:17:42 UTC - Size: 81.25 KB - 228 views
[2022-09-11 04:59:00]
Sierra_Chart Engineering - Posts: 24821
The "realtime" specification just indicates that those symbols are streaming. And potentially real-time. No you will not get real-time data for CFE.
