Date/Time: Fri, 18 Sep 2026 22:20:05 +0000
FTDX Eurex TechDAX futures contract specs wrong in SymbolSettings.scdataallservices.xml?
View Count: 1408
[2022-09-10 12:07:58]
uM8137 - Posts: 183
For Eurex futures contract FTDX, TechDAX:
0.5 tick, 5 euros per tick <- what https://www.eurex.com/ex-en/markets/idx/dax/TecDAX-Futures-253644 , the Eurex website says.
What the SymbolSettings.scdataallservices.xml from SC version 4911 says:
<settings>
<symbol>FTDX?##-EUREX</symbol>
<underlying-symbol>FTDX</underlying-symbol>
<tick-size>0.1</tick-size>
<currency-value-per-tick>10</currency-value-per-tick>
Which is correct?
[2022-09-11 10:26:35]
uM8137 - Posts: 183
The data seems to suggest that the Eurex website is correct and the SymbolSettings file should be updated.
Prices seem to be using 0.5 ticks; not 0.1 ticks.
{"Sym":"FTDXU22-EUREX", "StartDate":"2022/09/09",
{"2022-09-09T02:02:08.221-05:00", "Cl":2969.000000, "Sz":2, "Hi":2969.000000, "Lo":2969.000000, "Op":2969.000000, "OpenInterest":1, "AZ":2,\
"BZ":0}
{"2022-09-09T02:02:09.8-05:00", "Cl":2969.500000, "Sz":1, "Hi":2969.500000, "Lo":2969.500000, "Op":2969.500000, "OpenInterest":1, "AZ":1, "\
BZ":0}
{"2022-09-09T02:12:42.138-05:00", "Cl":2980.000000, "Sz":2, "Hi":2980.000000, "Lo":2980.000000, "Op":2980.000000, "OpenInterest":1, "AZ":2,\
"BZ":0}
{"2022-09-09T02:42:58.292-05:00", "Cl":2982.000000, "Sz":1, "Hi":2982.000000, "Lo":2982.000000, "Op":2982.000000, "OpenInterest":1, "AZ":1,\
"BZ":0}
{"2022-09-09T02:53:41.186-05:00", "Cl":2980.500000, "Sz":3, "Hi":2980.500000, "Lo":2980.500000, "Op":2980.500000, "OpenInterest":1, "AZ":0,\
"BZ":3}
{"2022-09-09T02:53:42.186-05:00", "Cl":2980.500000, "Sz":5, "Hi":2980.500000, "Lo":2980.500000, "Op":2980.500000, "OpenInterest":2, "AZ":0,\
"BZ":5}
{"2022-09-09T02:53:43.287-05:00", "Cl":2980.500000, "Sz":5, "Hi":2980.500000, "Lo":2980.500000, "Op":2980.500000, "OpenInterest":2, "AZ":0,\
"BZ":5}
{"2022-09-09T02:53:44.387-05:00", "Cl":2980.500000, "Sz":5, "Hi":2980.500000, "Lo":2980.500000, "Op":2980.500000, "OpenInterest":2, "AZ":0,\
"BZ":5}
{"2022-09-09T02:53:45.488-05:00", "Cl":2980.500000, "Sz":4, "Hi":2980.500000, "Lo":2980.500000, "Op":2980.500000, "OpenInterest":2, "AZ":0,\
"BZ":4}
[2022-09-12 08:23:09]
Sierra_Chart Engineering - Posts: 24890
We will correct this now.
